Setup megacore lib 6.0 on PC
Hi ,
When I started install.exe , an error message occurs :
Please do the following :
- Close any running programs
- Empty your temporary folder
- Check your Internet connection (Internet-based Setups)
Then try to run the Setup again
I have disabled all of my running and Antivirus programs. My Internet connection is totally ok.
In the message , it asks me to "Empty the temporary folder". Do you know where it is located ?
Did you get this issue before ?
Quan
--- Quote Start ---
originally posted by quan1328@Sep 27 2006, 03:08 AM
hi ,
when i started install.exe , an error message occurs :
please do the following :
- close any running programs
- empty your temporary folder
- check your internet connection (internet-based setups)
then try to run the setup again
i have disabled all of my running and antivirus programs. my internet connection is totally ok.
in the message , it asks me to "empty the temporary folder". do you know where it is located ?
did you get this issue before ?
thanks,
quan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18462)
--- quote end ---
--- Quote End ---
I&#39;m realy happy that someone other has the same problem.
I reported this problem to Altera in May this year. My support engeneer was completly clueless. I mailed with him several times and it seemed to me that he did not believe me and that I&#39;m the only one with that phenomena.
At last he recommended to reinstall my operating system.
At that day a closed the service request (number: 10545630: "Installation problem of megacore lib. V60") and was quite disappointed.
So I have still one PC without the Altera environment ... still unsolved.
But today I think we a two ... ;-)))
Kind regards Frank
Hi all,
Version V6.1 is okay again!!
Whatever the problem was, in the new version it&#39;s fixed.
V5.x was okay, V6.1 works, only V6.0 suffered from this
installation problem.
Frank
