Hi all,
With the uClinux-dist-20060803 release and patch V17: The "make linux image" has a strange behaviour: (Just after after a make clean make vendor_hwselect SYSPTF=~/... make make romfs) When I "make linux image" first time I get a non working image of about 500kB. Just after I launch a second time "make linux image" and I get a working image of about 1MB. What's the problem ? Thanks, LeFred.Link Copied
The first make didn't include the final romfs for initramfs.
The second make did. You'd follow the wiki's make steps.- Mark as New
you have to do "make romfs" before the first make.
it will create some dirs and files in romfs dir, so that initramfs script will work correctly afterward. make clean make vendor_hwselect SYSPTF=~/... make romfs <---- make make linux image- Mark as New
Thanks a lot for your help !
