Syntax problem
Hi, there
I am working on the verification of video over IP reference design. The hardware part is ok. But when I import the software folder from original reference design, and build the projects, some errors occurs, here I listed some of them:
extern alt_avalon_rtp_tx_dev rtp_tx;
error: syntax error before "rtp_tx"
static alt_avalon_udp_ip_design_parameters udp_params;
error: syntax error before "udp_params"
fec_settings[i].EnableFEC = 0;
error: request for member `EnableFEC' in something not a structure or union
Can anyone help me to understand what happened, and how to correct these errors? Thanks. They make me very confused.
The most probable cause of the error would be missing include/library file.
Check if all the include/library files are in the path expected by your software application.
