12619 Discussions
The unstable-nios2mmu Linux on the NEEK hanged out during start up.
Hi Guys,
I need someone's help.
I downloaded the unstable-nios2mmu Linux which is uploaded on 11st May
2010 at Gitorious.
When I run the compiled the SOF file of neek_ocm_spi_mmu, it hunged out
during boot.The message log is as follows at that time.
Does anyone give me an advice please?
【menuconfig】
NiosII Configration ---> NiosII FPGA Configration
---> neek_ocm_spi_mmu
【log】
/cygdrive/c/bin
[NiosII EDS]$ nios2-configure-sof cycloneIII_embedded_evaluation_kit_standard.s
of
Searching for SOF file:
in .
cycloneIII_embedded_evaluation_kit_standard.sof
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag -o p;cycloneIII_embedded_eval
Info: Using programming cable "USB-Blaster [USB-0]"
Info: Started Programmer operation at Mon May 17 13:35:00 2010
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020F30DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Mon May 17 13:35:01 2010
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 60 megabytes
Info: Processing ended: Mon May 17 13:35:01 2010
Info: Elapsed time: 00:00:06
Info: Total CPU time (on all processors): 00:00:04
/cygdrive/c/bin
[NiosII EDS]$ nios2-download -g linux.initramfs.gz
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 3122KB in 56.1s (55.6KB/s)
Verified OK
Starting processor at address 0xC01CD238
/cygdrive/c/bin
[NiosII EDS]$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
U-Boot 2010.03-00312-g8e95ef1-dirty (May 06 2010 - 15:09:42)
CLinux version 2.6.34-rc2 (root@ubuntu-vm) (gcc version 4.1.2)# 17 Mon May 17 13
:31:14 JST 2010
bootconsole [early0] enabled
Early printk initialized
Linux/Nios II-MMU
init_bootmem_node(?,0x326, 0x0, 0x2000)
free_bootmem(0x326000, 0x1cda000)
reserve_bootmem(0x326000, 0x400)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line:
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
We have 8192 pages of RAM
Memory available: 29248k/3220k RAM, 0k/0k ROM (1844k kernel code, 1375k data)
NR_IRQS:32
Calibrating delay loop... 49.15 BogoMIPS (lpj=245760)
Mount-cache hash table entries: 512
nios2-terminal: exiting due to ^C on host
/cygdrive/c/bin
[NiosII EDS]$
I was debugging, linux-2.6\kernel\sched.c sched_init () is called in, context_switch () donot return from processing.
Could I ask you advice something?
Yes, we are tracking the same problem. I guess something wrong in the inits. Please continue your debugging.
- Hippo
Thanks for reply!
I understand that I have come up with the same problem.
Continue to try to debugging.
