My board "Nios II Development Kit, Cyclone II Edition (2C35)"!
I compile U-BOOT1.14! Download into flash 0X0! But get error:U-Boot 1.1.4 (Aug 28 2006 - 13:57:06)
CPU : Nios-II
SYSID : 8d9e207b, Fri May 13 18:37:17 2005
BOARD : Altera EP-2C35
*** Warning - bad CRC, using default environment
==> bdi
mem start = 0x04000000
mem size = 0x02000000
flash start = 0x00000000
flash size = 0x01000000
flash offset= 0x00000000
sram start = 0x02000000
sram size = 0x00200000
ethaddr = 08:00:3E:26:0A:5B
ip_addr = 192.168.2.21
baudrate = 115200 bps
==> printenv
baudrate=115200
ethaddr=08:00:3e:26:0a:5b
ipaddr=192.168.2.21
serverip=192.168.2.16
netmask=255.255.255.0
stdin=serial
stdout=serial
stderr=serial
Environment size: 147/65532 bytes
when i ping other host, ==> ping 192.168.2.1
SMC91111:PHY reset timed out
Warning: MAC addresses don't match:
HW MAC address: 01:FF:EF:FF:FF:FF
"ethaddr" value: 08:00:3E:26:0A:5B
Using MAC Address 08:00:3E:26:0A:5B
SMC91111: Memory allocation failed.
Then host down!!! Who can help me? Thank you very much!
--- Quote Start --- originally posted by topgun@Aug 30 2006, 01:40 AM my board "nios ii development kit, cyclone ii edition (2c35)"!
i compile u-boot1.14! download into flash 0x0!
but get error:
u-boot 1.1.4 (aug 28 2006 - 13:57:06)
cpu : nios-ii
sysid : 8d9e207b, fri may 13 18:37:17 2005
board : altera ep-2c35
*** warning - bad crc, using default environment
==> bdi
ethaddr = 08:00:3e:26:0a:5b
==> printenv
baudrate=115200
ipaddr=192.168.2.21
stdin=serial
stdout=serial
stderr=serial
environment size: 147/65532 bytes
smc91111:phy reset timed out
warning: mac addresses don't match:
hw mac address: 01:ff:ef:ff:ff:ff
"ethaddr" value: 08:00:3e:26:0a:5b
using mac address 08:00:3e:26:0a:5b
smc91111: memory allocation failed.
then host down!!!
who can help me? thank you very much!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17945)</div> --- Quote End --- the problem is the Memory allocation failed
But how to fix?
--- Quote Start --- originally posted by topgun@Sep 1 2006, 03:15 AM but how to fix?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18001)
--- quote end ---
--- Quote End --- Are not the solutions it and I'm sorry. I also am coming the same phenomenon. And, the source read. Then, these kind of things were written in about the 600th line smc91111.c /* FIXME: the ALLOC_INT bit never gets set * * so the following will always give a * * memory allocation error. * * same code works in armboot though * * -ro */ However, it is not understood what the "same code" is. armboot Reference http://armboot.sourceforge.net/ (http://armboot.sourceforge.net/)
