VFork
I tried to compile a small example and I get an error (implicit declaration vfork()). Is it possible to create a new process with uClinux. An other point, i'm usign Nios IDE to compile my application.
int main() {
int taille, lecture, i;
struct sockaddr_in serveur;
char tampon[1024];
int nds, ds;
signal(SIGINT, intercept);
if ((ds = socket(AF_INET, SOCK_STREAM, 0 )) < 0) exit(1);
serveur.sin_family = AF_INET;
serveur.sin_addr.s_addr = INADDR_ANY;
serveur.sin_port = SERV_PORT;
if (bind(ds, (struct sockaddr *)&serveur, sizeof serveur) < 0) exit(1);
taille = sizeof(serveur);
if (getsockname(ds, (struct sockaddr *)&serveur, &taille) < 0 ) exit(1);
listen(ds, 5);
while (1) {
if (( nds = accept(ds, (struct sockaddr *)0, (int *)0)) == -1 ) exit(1);
if (vfork() == 0) { // ERROR HERE!!!!
if ((lecture = read(nds, tampon, 6))==-1) exit(1);
printf("Je viens de lire: %s\n", tampon);
exit(0);
You forgot to indicate which files you&#39;re including -- vfork requires sys/types.h and unistd.h
Incidentally,
from the uclinux faq (http://www.uclinux.org/pub/uclinux/faq.shtml#2-5)
