12748 Discussions
Why can not set Program memory to FLASH
I make a simple SOPC Builder system with only EPCS+onchip ram and without other offchip Flash and sram/sdram. I test it under Nios II IDE that it does work when program memory(.text) and read-only data memory(.rodata) are set to onchip ram.
But when I try to set .text and .rodata to EPCS under system library properties, the program can not be downloaded to the board, displaying the following message: Leaving target processor paused.
Why can not set these read-only program or data to FLASH?
I don't think you'd want to run your code from a serial flash, like an EPCS, and, even if you did, the controller that ships with Nios II does not support it. The contoller contains a small onchip memory to hold a bootloader.
There is an alternate EPCS component, which you can find on this forum, which will allow you to do what you want.
- slacker
--- Quote Start ---
originally posted by seu_xugh@Sep 1 2005, 09:53 PM
i make a simple sopc builder system with only epcs+onchip ram and without other offchip flash and sram/sdram. i test it under nios ii ide that it does work when program memory(.text) and read-only data memory(.rodata) are set to onchip ram.
but when i try to set .text and .rodata to epcs under system library properties, the program can not be downloaded to the board, displaying the following message: leaving target processor paused.
why can not set these read-only program or data to flash?
--- Quote End ---
Oh you certainly can
But Download to Board does not work with Flash
If you want to download the code into flash, use the flash programmer.
regards
Pavan
Hi seu_xugh,
The memory associated with the epcs_controller is read only. So just downloading code to this
memory via the IDE will not work. And the flash programmer is used to program the eeprom on
the epcs device, not the on-chip rom.
When you do this, you're telling the the IDE that you want your code to run out of the epcs controller
boot rom.
If this is what you really want, the flash programmer will not work either ... you'll need to modify the
contents of your epcs_controller_boot_rom.hex file -- and you will no longer have the benefit of the
boot code. In this case you may find it easier to simply use the asmi component and an onchip rom/ram.
If you want to store your program in the epcs and have it automatically executed when the system
boots, then you need to set your reset address to the epcs_controller, and leave your application
.text, .data and other sections mapped to some ram.
--Scott
