12618 Discussions
Wrong information on NIOSWIKI? (Related to the timer)
Hello i am making a hardware design and i am following NIOSWIKI orientations, however if i select my IRQ0 to be the timer (as NIOSWIKI tells me to do) my design doesnt work, the linux doesnt boot.
But if i select my ECPS_CONTROLLER as IRQ0 everything runs just fine.
Is this correct? Thanks
AFAIK, IRQ 0 should not be used at all, as same is a fallback if a correct handler is not found.
-Michael
