i use altera ep2c35 board. when i used c2h to accelarate the functions,i met a problem like this:
c:/altera/kits/nios2_60/components/altera_avalon_c_hardware_accelerator/c_declaration.pm 113 CALLED (c_code_block::user_error) c:/altera/kits/nios2_60/components/altera_avalon_c_hardware_accelerator/c_code_block.pm 6083 CALLED (c_code_block::user_message) WHERE '::C2H ERROR: copysign already declared at file: , line:' OCCURRED on c:/altera/kits/nios2_60/components/altera_avalon_c_hardware_accelerator/c_code_block.pm 6136 so i can't pass through the build! someone can help me! thanks!Link Copied
Without seeing the code this will be difficult to debug (our fault, we are improving the error messages). If you can't show the code submit a service request at this address:
https://mysupport.altera.com/eservice/ (https://mysupport.altera.com/eservice/) Be sure to put "C2H" in the title such as "C2H generation error".
