12612 Discussions
about cfi-flash for DE2 board....
hi hippo
my cif-flash addr is 0x0800000.
Dose i need to change my cfi-flash addr mapping MTD partition of altera.c ?
Thx !
--- Quote Start ---
originally posted by jay_1025@May 29 2006, 06:22 PM
hi hippo
dose i need to change my cfi-flash addr mapping mtd partition of altera.c ?
thx !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15658)
--- quote end ---
--- Quote End ---
Yes, you must change the map start and size to that of your cfi flash.
TO_BE_DONE
No, you should not change cfi in sopc builder.
You should only change mtd/maps/altera.c .
(if you change in sopc builder, you need to regenerate hardware and compile a new sof,
then in the kernel dir, make ... clean, make ... hwselect ...new ptf ......
You have to rebuild almost everything. )
--- Quote Start ---
originally posted by hippo@May 29 2006, 08:25 AM
no, you should not change cfi in sopc builder.
you should only change mtd/maps/altera.c.
you have to rebuild almost everything. )
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15668)
--- quote end ---
--- Quote End ---
hippo
I have regenerated hw(.ptf) and compiled a new .sof on QII,but i didn&#39;t used "make clean" this step under linux.
finally,i have proplem about cpu start addr, when i have changed sdram addr in sopc builer,and how to edit cpu start addr in kernel configure ?
Thx !!!
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
finally,i have proplem about cpu start addr, when i have changed sdram addr in sopc builer,and how to edit cpu start addr in kernel configure ?[/b]
--- Quote End ---
You need to make clean, and make hwselect.
The hwselect script will update cpu start address linkage in kernel.
--- Quote Start ---
originally posted by hippo@May 29 2006, 08:21 PM
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15672)</div>
[/b]
--- Quote End ---
hi hippo
I have already done according to what you said("make clean","make hwselect".....)
Finally, the same problem apperas,again. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Why I always meet the same problem ?
and which place i didn&#39;t set and miss ?
so far, i directly download zImage to sdram under sdk shell.
i have compiled my project and generated new up4.rbf on QII.
i have two guestions about how to program epcs serial flash ?(storing hw config and zImge):
Q1: how to download my up4.rbf to epcs and use nios2-flash-programmer under sdk shell ?
Q2:Does i need to change format of my zImage ?
how to download my zImage to epcs and give spectify addr with using nios2- flash-programmer commad ?
can you give me a example how to use nios2-flash-programmer command ?
THx !
Look in the wiki, http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/flashprogrammer
you must use Nios2 v5.1 sp1 or later to program the EPCS correctly.
Check your kernel dir, include/nios2_system.h
or check in sopc builder , to find out the epcs controller&#39;s base address.
If you want Nios II to boot from EPCS device, you have to set "reset address" to EPCS device in cpu option, SOPC builder.
Then generate hardware in SOPC builder, and compile to sof.
You have to update kernel, by "make ... clean" , "make.... hwselect.." and rebuild the kernel.
If you use EPCS flash, find out and change the sof path and epcs base (replace 0x00900800) below.
on nios2 sdk shell,
cd arch/nios2nommu/boot# Creating .flash file for the FPGA configuration
sof2flash --epcs --input=your_new_de2.sof --output=standard.flash# Programming flash with the FPGA configuration
nios2-flash-programmer --epcs --base=0x00900800 standard.flash# Creating .flash file for the project
elf2flash --epcs --after=standard.flash --input=zImage --output=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_epcs.srec# Programming flash with the project
nios2-flash-programmer --epcs --base=0x00900800 epcs_controller.flash
Hi hippo
Thank u very much !
I can program sof.flash and zImage.flash to epcs falsh under sdk shell,
and i have set "reset addr" to epcs device in sopc builder, but i don&#39;t boot zImage from epcs flash. i sure my hw configure data is OK.because i can directly download zImage to sdram and execute "nios2-termial" command to boot uClinux. so i don&#39;t need to download .sof every time.
I have already tested it several times but can&#39;t succeed.
what is something cause can&#39;t boot from epcs flash ?
or i need to enable and disable some options in kerneal configure.
Thx !
hi hippo
I can boot from epcs flash,now.
If i want to execute command under uclinux os that need to cost more than 1 minutes at least.
Why need to spend so much time to boot from epcs flash ?
When I ececute "free" command under console that can know not increase space of free memory.
Finally, i can&#39;t mount jffs2 mtdblock0 to mnt dir and meet same problem again.. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Thx !
1. Which nios2 version do you use ?
Old version is very slow.
2. Boot from EPCS or CFI will not increase free memory, it is the same as nios2-download to sdram.
You may follow my latest uClinux-dist , it will increase free memory.
http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist
3. Please post your nios2_system.h , altera.c and boot message again.
You may look in /proc for the info of your mtdblock0.
TO_BE_DONE
Remove this line from your map in altera.c , which made it read-only, but we want to write.
.mask_flags =MTD_WRITEABLE,
Which quartus version do you use?
Which Nios II version do you use? (eg, v5.0 ?) ( not buildroot version)
--- Quote Start ---
originally posted by hippo@May 31 2006, 07:07 AM
remove this line from your map in altera.c , which made it read-only, but we want to write.
.mask_flags =mtd_writeable,
which quartus version do you use?
which nios ii version do you use?  (eg, v5.0 ?) ( not buildroot version)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15720)
--- quote end ---
--- Quote End ---
hi hippo
My QII version is 5.1 sp2 and Nios II version is 5.1 sp1.
I am using DE2 examples for 1.0 version.
Does i need to upgrade DE2 version to 1.3 ?
--- Quote Start ---
# mount -t jffs2 /dev/mtdblock0 /mnt# ls /mnt# cd /proc# more mounts
rootfs / rootfs rw 0 0
proc /proc proc rw 0 0
sysfs /sys sysfs rw 0 0
none /proc/bus/usb usbfs rw 0 0
/dev/mtdblock0 /mnt jffs2 rw 0 0# umount /mnt[/b]
--- Quote End ---
It seems that I can mount mtdblock0 to mnt dir.
Thx !
--- Quote Start ---
--- Quote End ---
Hi hippo
Thank u !!!!
I will disable initramfs option in kernel configure and copy rootfs to mnt dir ,then rebuild kernel.
Thx !
hi hippo
I have disabled initramfs path to empty and copied rootfs to ~/rootfs/mnt dir, then rebuilt kernel and reprogramed zImage.flash to epcs flash.but i can&#39;t execute command under uclinux .
--- Quote Start ---
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6768k/8192k RAM, 0k/0k ROM (1185k kernel code, 144k data)
Mount-cache hash table entries: 512
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
JFFS2 version 2.2. (NAND) © 2001-2003 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80481120 (irq = 1) is a jtag_uart
Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 1 MTD partitions on "Altera NDK flash (AMD)":
0x00000000-0x00400000 : "jffs2"
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362_hc_reset:
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd: irq 4, io mem 0x804810d0
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL:    2 *  256:      512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8):  1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8):  2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968    128
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 4
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)[/b]
--- Quote End ---
Before, I can mount mtdblock0 to mnt dir and mtdblock0 is blank , because i have not store something in flash.
How to use cfi-flash for jffs2 on uclinux ?
Thx !
add "rootfstype=jffs2" to kernel command line.
You should umount pseudo filesystem , such as /proc/bus/usb, /proc,/sys,
before "cp -a" or
skip the cp and use mkdir instead.
--- Quote Start ---
you should umount pseudo filesystem , such as /proc/bus/usb, /proc,/sys,
before "cp -a"  or
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15736)
--- quote end ---
--- Quote End ---
hi hippo
So ,there are have root=/dev/mtdblock and rootfstype=jffs2 in kernel command line. Is right ?
I don&#39;t konw how to umount pseudo filesystem ? where ?
Can you explain about it more detial ?
Thx !
If you want to root fs on the jffs2 drive, erase the flash, and on Nios II uClinux,
mount -t jffs2 /dev/mtdblock0 /mnt cd /mnt mkdir proc sys var tmp mnt cp -a init /etc /dev /bin /sbin /lib /usr /root /home . umount /mnt
Config kernel command line "root=/dev/mtdblock0 rootfstype=jffs2" ,
and empty the initramfs path. Then rebuild kernel.
hi hippo
I have disable kernel path to empty and rebuild kernel .
My new kernel size reduce much more that around is 587KB.
But ,i can not execute command on uclinux.
--- Quote Start ---
uClinux/Nios II
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 rootfstype=jffs2
isp1362_hc_reset:
isp1362_hc_start:
VFS: Mounted root (jffs2 filesystem) readonly.
Freeing unused kernel memory: 44k freed (0x938000 - 0x942000)
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.[/b]
--- Quote End ---
Do you know why can not find init ?
Thx !
Sorry, the cp of init is incorrect. init => /init
cp -a /init /etc /dev /bin /sbin /lib /usr /root /home .
