adding network to linux image
Can someone help me. I have successfully built a nios ii linux zImage, and able to boot it.
However, I don't seem to be able to make it run ifconfig eth0 192.168.50.63
I tried to change romfs/etc/rc before doing a
make
make linux image
But, it doesn't work. Can someone please help ? What do i need to do ?
--- Quote Start ---
originally posted by albertyong88@Aug 14 2006, 10:08 AM
hello,
can someone help me. i have successfully built a nios ii linux zimage, and able to boot it.
however, i don't seem to be able to make it run ifconfig eth0 192.168.50.63
i tried to change romfs/etc/rc before doing a
make
make linux image
but, it doesn't work. can someone please help ? what do i need to do ?
thanks
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17579)
--- quote end ---
--- Quote End ---
I subsequently went to vendor/Altera/nios2nommu/rc. Changed it, and it makes no different
Do I need to do a make clean ?
--- Quote Start ---
hello,
however, i don&#39;t seem to be able to make it run ifconfig eth0 192.168.50.63
make
make linux image
but, it doesn&#39;t work. can someone please help ? what do i need to do ?
thanks
--- quote end ---
--- Quote End ---
Hi, I did the following and it works:
make clean
rm -r romfs/
make linux_hwselect SYSPTF=~/uClinux-dist-test/std_2C35.ptf
make romfs
make menuconfig
make
make linux image
Just wondering if anyone knows the stages I can ignore. Are there documents describing each process for making a linux image ?
