Hi all,
I try to boot from QSPI Flash (S25FL512S) but I am having some difficulties. I have the same DDR3 as altera cyclone v soc board + two QSPI S25FL512S connected to the hps side. Input clock for FPGA and HPS = 25MHz. First, I followed the tutorial on rocketboard: http://rocketboards.org/foswiki/view/documentation/gsrd131qspiboot but the flash was not detected, then, I added these lines in u-boot spl file spansion.c
.idcode1 = 0x0220,
.idcode2 = 0x4d00,
.pages_per_sector = 256,
.nr_sectors = 1024,
.name = "S25FL512S",
but i still have a problem, the board reboot non stop with this log rather than going to u-boot
U-Boot SPL 2013.01.01 (Jun 29 2015 - 17:26:52)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 400 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 488 KHz
CLOCK: QSPI clock 200000 KHz
RESET: WARM
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 512 MiB
SF: Read data capture delay calibrated to 1 (0 - 2)
SF: Detected S25FL512S
I have no idea, I have tried many things. I can boot with the arrow sockit but the flash is different. there is something missing :/ I attached my quartus design. thank you for your help
I'm pretty sure this is because the U-Boot port on which this preloader is based upon does not fully support this flash. As seen in the datasheet (http://www.spansion.com/support/datasheets/s25fl512s_00.pdf), the bit EXTADD of the Bank Address Register is set to 0 by default, and this means that the FAST_READ (0Bh) command used by U-Boot expects to be followed by a 3-byte address, but since the device is > 16 MB, U-Boot automatically uses a 4-byte address! So the preloader copies garbage to the DDR, and then tries to run it, the watchdog is triggered, and so on... There is also a similar problem related to the Normal or Quad operation. The changes are not too difficult to implement, but actually Altera pushed last week a commit that adds this support! So, you can take a look at this commit, and see if it solves your problem: https://github.com/altera-opensource/u-boot-socfpga/commit/5a47f31c98e6c70185f3423bc82f3414cb25ca2c Hope this helps!- Mark as New
Hi slesne,
thank you for the information I saw this patch only spansion.c change, now I also use this version for the preloader and u-boot + i added some modifications in uboot-socfpga/drivers/mtd/spi/spansion.c 1. Replace flash->sector_size = 256 * params->pages_per_sector; With: flash->sector_size = 512 * params->pages_per_sector; 2. I added { .idcode1 = 0x0220, .idcode2 = 0x4d00, .pages_per_sector = 512, .nr_sectors = 256, .name = "S25FL512S", }, Also change the following in uboot-socfpga/include/configs/socfpga_common.h: From this: # define CONFIG_CQSPI_PAGE_SIZE (256) To this: # define CONFIG_CQSPI_PAGE_SIZE (512) but i still have the same problem so run the preloader code step by step with the debugger i stop at this line (line 191 in spl.c) image_entry((u32 *)boot_params_ptr); I think my changes to support this flash are not good to jump to the next image- Mark as New
TO_BE_DONE
This might not be the only problem, but this print of the image name is a bit sketchy, I've had some trouble with it in the past. (I think that the spl_image.name doesn't end with a null char, so it reads too far in the memory, this might be what triggers the ECC error) I would advise commenting it out! (uboot-socfpga/common/spl/spl.c, around line 116) Hope this helps!- Mark as New
Hi slesne,
you have right
U-Boot SPL 2013.01.01 (Jul 02 2015 - 16:30:48)
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 330 MHz
CLOCK: QSPI clock 400000 KHz
RESET: COLD
SDRAM: 512 MiB
SF: Read data capture delay calibrated to 3 (0 - 7)
SF: Detected S25FL512S with page size 262144, total: 67108864
U-Boot 2013.01.01-00114-g9381569-dirty (Jul 02 2015 - 16:30:54)
CPU : Altera SOCFPGA Platform
I2C: ready
DRAM: 256 MiB
MMC: ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
** Bad device mmc 0 **
Optional boot script not found. Continuing to boot normally
Bad Linux ARM zImage magic!
SOCFPGA_CYCLONE5#
Now I will a linux image Thanks a lot for your help
Hi slesne,
Now it works ! thank you Hayder H CIELE Ingenierie ;-)- Mark as New
Your conversations are very help ful for me.After enabling 4byte addressing repeat log message problem solved. I stored my baremetal application on qspi flash by using following commands mkimage -A arm -O u-boot -T standalone -C none -a 0x02100000 -e 0 -n "baremetal image" -d hwlib.bin hwlib.img quartus_hps -c 1 -o PV -a 0x60000 hwlib.img.bin After debugging through printf statements it is stopping at following line image_entry((u32 *)boot_params_ptr); After this statement it's not jumping to baremetal application which i have stored at 0x6000 location. Any suggestions is appreciated. Hayder what modifications u have done to jump to u-boot while it was struck at image_entry((u32 *)boot_params_ptr); waiting for ur replies- Mark as New
--- Quote Start --- mkimage -A arm -O u-boot -T standalone -C none -a 0x02100000 -e 0 -n "baremetal image" -d hwlib.bin hwlib.img quartus_hps -c 1 -o PV -a 0x60000 hwlib.img.bin --- Quote End --- Hi, I think you need to use 0x02100040 as the load address (-a switch), to account for the 64-byte header of the image. You can take a look at the "Unhosted" example from this page: https://www.altera.com/support/support-resources/design-examples/soc.html Hope this helps!
Hi slesne,
Thanks for the reply.I tried with 0x02100040 as the load address,still i am facing same problem. The link u have given will be useful in future. currently I am working cyclone v soc custom board.In board only 3 options are provided(boot from qspi,NAND and FPGA).when ever i try to debug project through DS-5 in boot from qspi flash mode ,it's always throwing following error Target Message: Could not determine target state currently i can't debug example projects on board. Any suggestions are welcome to proceed Thank you- Mark as New
Hayder what modifications u have done to jump to u-boot while it was struck at image_entry((u32 *)boot_params_ptr); I am waiting for ur suggestion Mr.slesne. Thanks- Mark as New
I am working on cyclone V SOC custom board and i want to boot bare metal application from qspi flash(S25FL512S). I dumped the quad custom preloader image(preloader-mkpimage.bin) into the flash using the command "quartus_hps -c 1 -o PV -a 0 preloader-mkpimage.bin". I built the helloworld example bare metal application from GHRD and created the the bootable image using the commands, objcopy -I elf32-little -O binary hello.axf hello.bin mkimage -A arm -O u-boot -T standalone -C none -a 0x01000040 -e 0 -n "baremetal image" -d hello.bin hello.img I dumped the bootable image on qspi using quartus_hps -c 1 -o PV -a 0x60000 hello.bin After resetting the board(cold and warm reset) preloader prints are printed on console but hello world is not printed. Same problem with the hwlib example bare metal application. When i tried to boot uboot from qspi it is booting properly. I used following commands for that, mkimage -A arm -O u-boot -T standalone -C none -a 0x01000040 -e 0 -n "U-Boot image" -d u-boot.bin u-boot.img quartus_hps -c 1 -o PV -a 0x60000 u-boot.img I am wondering why i am not able to see any bare metal application prints on console. Any help would be greatly appreciated.
Topic Options
