busybox error
when i built busybox according <linux referece guide>, everythings gone well
except when linux startup, the error comes:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
0x00600000-0x00700000 : "User configuration"
0x00700000-0x00800000 : "safe configuration"
i2c /dev entries driver
i2c-oc: i2c Opencores adapter driver
Opencores i2c algorithm module
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
NET: Registered protocol family 1
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 60k freed (0x116e000 - 0x117c000)
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.[/b]
--- Quote End ---
I guess it is because of no init.lnk in /bin but in /sbin
So I copy /sbin/init.lnk to /bin, but failed again,the same error occured.
Can you help me?
Euhm
I&#39;m pretty much clueless as it comes to the latest incarnations of Windows, but a x.lnk file seems to be a link to a certain file.
From what I remember (>5 yrs ago), a *.lnk file is a txt file with in it the txt where the file is linking to.
I doubt that would be recognised by a Unix based system.
I found the reason.
When I "make install", "busybox" copied to <project>/target, but it was rw only not excutable. So I "mv busybox busybox.exe" (chmod 777 in cygwin was useless during my test).
Then "build fs" , upload, it worked.
PS: my classmates&#39; work is "xrw" of "busybox" after "make install", so I don&#39;t know why things goes wrong in my way.
Hi
I have sthe same problem with the basic kernel and filesystem project. I just go through the quick start guide but get the same output you&#39;ve pasted. I don&#39;t find anything under the filesystem/target that I should make executable. Any idea on what can go wrong when I just want to get a login to uClinux ?
Nir
What&#39;s your error message?
Hi
It was my dumb mistake, sorry.
Nir
