12610 Discussions
dts .compatibility for pata_platform.c
Thanks in advance.
I'm using the Altera MAX0 evaluation board with the ghrd design PLUS added an IDE interface on the HSMC connector (it has a compact flash).
I am now using the current Linux-socfpg and I modified the kernel to add SCSI disk support and ATA PATA generic pata (pata_patform.c).
My problem is what do I put for compatibility in the *.dts so the OS will recognize I have a Compact Flash?
If I grep ".compatibility" the pata_platform.c source has NO .compatibility statement. I have tried "ata-generic" "electra-ide" since they
are both in the OpenFrame driver pata_of_platform.c which I also have enabled.
I have used this configuration before with the old non-mmu uCLinux-dist and the CF worked fine - of course there was no device tree.
