12693 Discussions
exposing ports outside of SOPC
Good Afternoon
Sorry but I am new to NIOS and SOPC builder. But I am trying to create a two port memory where one port is connected to the NIOS using AValong-mm so I can read and write to the memory by the CPU, but the second port is exposed outside of SOPC block so I can access it outside of the SOPC package? A generic way to ask is "are there a way to expose ports to the external world in SOPC other than create your own device?"
Thanks for your help.
Victor
What you need to do is create an avalon master port and export it outside of SoPC builder. The easiest way to do this is to create a new component using the component wizard. Use the "Templates" to create a new Avalon Memory Mapped Master template. Because the component is not based on HDL, it will automatically export the signals outside SoPC Builder. You should create a master with a 32-bit address bus and a 32-bit data bus. It is your responsibility to make sure you address slave components on the bus correctly.
Jake
<div class='quotetop'>QUOTE (jakobjones @ Jul 11 2009, 08:20 PM) <{post_snapback}> (index.php?act=findpost&pid=23082)</div>
--- Quote Start ---
Jake[/b]
--- Quote End ---
Thank You
Victor
