how to ext_flash.flash-->.bin
hello all,
I want to transform the application code .elf file to .bin,but the IDE seems to only .flash file. how to do this ? are there some tools?
thank you!
Hi there,
use nio2-elf-objcopy
you will probably want something like:
nios2-elf-objcopy -O binary input_file.elf output_file.bin
...DW
--- Quote Start ---
originally posted by cybdenw@Apr 6 2005, 02:09 AM
hi there,
nios2-elf-objcopy -o binary input_file.elf output_file.bin
regards,
  ...dw
--- Quote End ---
hello cybdenw
I used
the input file .elf :409KB but the output_file.bin is 9M
it seems wrong
i use the following script, it converts first
from .elf -> .flash and then from .flash(srec) -> .bin
you have to adjust some settings in the script (addresses)
SCRIPT: elf2bin.sh
use: elf2bin <ELFFILE> <BINFILE>
# ################################################################################ CONVERT NIOS ELF-FILE TO BINARY FILE
SRC_FILE=$1
SRC_FILENAME=${SRC_FILE##*/} # returns the file name with the all directories removed:
SRC_FILENAME_NOEXT=${SRC_FILENAME%%.*} # returns the path with all extensions removed:
SRC_FILEBASE=${SRC_FILE%.*} # remove last extension
# echo "SRC_FILENAME :"$SRC_FILENAME# echo "SRC_FILENAME_NOEXT :"$SRC_FILENAME_NOEXT# echo "SRC_FILEBASE :"$SRC_FILEBASE
DST_FILE=$2
echo ----------------------------------------------------------------------------
echo "CONVERT ELF FILE : "$SRC_FILE
echo "to BINARY FILE : "$DST_FILE
# ################################################################################ COPY FILE# cp ../1DVI02_SOFTWARE/$FILE/DEBUG/$FILE.elf $FILE.elf -v
# ################################################################################ CONVERT ELF->FLASH FILE
# ELF2FLASH .ELF INPUT FILE
ELF_FILE=$SRC_FILEBASE.elf
# ELF2FLASH .FLASH OUTPUT FILE
FLASH_FILE=$SRC_FILENAME_NOEXT.flash
BINARY_FILE=$DST_FILE
# ##################### SETTINGS FOR ELF2FLASH CONVERTER
FLASHBASE=0x00000000
FLASHEND=0x007FFFFF
RESETADDRESS=0x00000000
FLASH_ID=U1
# BOOTLOADER
BOOTLOADER=boot_loader_cfi.srec
echo "CONVERT FILE : "$ELF_FILE
echo "to : "$FLASH_FILE
echo "BOOTLOADER : "$BOOTLOADER
echo "FLASH ID : "$FLASH_ID
echo "FLASH BASE ADD : "$FLASHBASE
echo "FLASH END ADD : "$FLASHEND
echo "RESET ADD : "$RESETADDRESS
elf2flash --input=$ELF_FILE --output=$FLASH_FILE --base=$FLASHBASE --end=$FLASHEND --boot=$BOOTLOADER --reset=$RESETADDRESS --flash=$FLASH_ID --verbose
if [ $? != 0 ]
then
echo "--- !!! ERROR !!! !!! ERROR !!! !!! ERROR !!! !!! ERROR !!! ---"
exit -1
fi
# ################################################################################ CONVERT FLASH FILE->BINARY FILE
echo "CONVERT FILE : "$FLASH_FILE
echo "to : "$BINARY_FILE
nios2-elf-objcopy -I srec -O binary $FLASH_FILE $BINARY_FILE -v
rm -v $FLASH_FILE
ECHO "PRESS ANY KEY"
read
thank u very much,I got it.
