12748 Discussions
how to modify the ethernet driver
dear all,
I do according to hippo, now i can run uclinux on my custom board ,because my board is not the altera board ,so i should modify the lan91c111 driver ,could you give me how to modify the ethernet driver?
best regards
--- Quote Start ---
originally posted by nwpu_zhf2004@Jul 2 2006, 11:04 PM
dear all,
        i do according to hippo, now i can run uclinux on my custom board ,because my board is not the altera board ,so i should modify the lan91c111 driver ,could you give me how to modify the ethernet driver?
best regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16609)
--- quote end ---
--- Quote End ---
If you follow altera dev board to design your scm91111, it should run without modification.
check include/nios2_system.h
does the uclinux detect smc91111 during bootup?
I have ever run a web server on my costum board(LAN91C111 is work in 16 bit with nios2,this is not same altera dev board)with uCOS2.I think the hardware of 91c111 is good.
Now I compile the 91c111 driver into the uClinux,but the 91c111 does not run because the led of the J45 is not light.
Should I modfide the 91c111 driver?
--- Quote Start ---
originally posted by nwpu_zhf2004@Jul 3 2006, 12:48 PM
i have ever run a web server on my costum board(lan91c111 is work in 16 bit with nios2,this is not same altera dev board)with ucos2.i think the hardware of 91c111 is good.
      now i compile the 91c111 driver into the uclinux,but the 91c111 does not run because the led of the j45 is not light.
      should i modfide the 91c111 driver?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16619)
--- quote end ---
--- Quote End ---
in drivers/net/smc91111.c
try define CONFIG_SMC16BITONLY
