kernel bug in page mapping
lwbuss had found a page mapping bug in the kernel 2.6.11 and newer. Best thanks to lwbuss.
please check if the patches work for you,
Index: include/asm-nios2nommu/io.h =================================================================== --- include/asm-nios2nommu/io.h    (revision 9) +++ include/asm-nios2nommu/io.h    (working copy) @@ -225,3 +225,3 @@ /* Pages to physical address... */ -#define page_to_phys(page)      ((page - mem_map) << PAGE_SHIFT) -#define page_to_bus(page)       ((page - mem_map) << PAGE_SHIFT) +#define page_to_phys(page)      __pa(page_to_virt(page)) +#define page_to_bus(page)       __pa(page_to_virt(page))
ps, use "-l" option in patch command to ignore white space, or better do it by hand.
Here are the patches from lwbuss.
I think the previous patch in post#1 is enough.
They do the same things.
diff -Nru orig/linux-2.6.16.2/arch/nios2nommu/drivers/pci/altpci.c current/linux-2.6.16.2/arch/nios2nommu/drivers/pci/altpci.c --- orig/linux-2.6.16.2/arch/nios2nommu/drivers/pci/altpci.c 2006-04-28 10:23:20.000000000 -0600 +++ current/linux-2.6.16.2/arch/nios2nommu/drivers/pci/altpci.c 2006-04-26 14:57:43.000000000 -0600 @@ -43,7 +43,7 @@# define ALT_PCI_IO_BASE (pciio)# define ALT_PCI_IO_SIZE 0x100000# define ALT_PCI_MEMORY_BASE (pcimm) -#define ALT_PCI_MEM_SIZE 0x100000 +#define ALT_PCI_MEM_SIZE 0x200000 /* * Functions for accessing PCI configuration space with type 1 accesses diff -Nru orig/linux-2.6.16.2/arch/nios2nommu/mm/dma-noncoherent.c current/linux-2.6.16.2/arch/nios2nommu/mm/dma-noncoherent.c --- orig/linux-2.6.16.2/arch/nios2nommu/mm/dma-noncoherent.c 2006-04-28 10:23:20.000000000 -0600 +++ current/linux-2.6.16.2/arch/nios2nommu/mm/dma-noncoherent.c 2006-04-28 10:22:11.000000000 -0600 @@ -140,7 +140,9 @@ addr = (unsigned long) page_address(sg->page); if (addr) { __dma_sync(addr + sg->offset, sg->length, direction); - sg->dma_address = (dma_addr_t)page_to_phys(sg->page) + //sg->dma_address = (dma_addr_t)page_to_phys(sg->page) + // + sg->offset; + sg->dma_address = (dma_addr_t)page_address(sg->page) + sg->offset; } } @@ -160,7 +162,13 @@ addr = (unsigned long) page_address(page) + offset; dma_cache_wback_inv(addr, size); - return page_to_phys(page) + offset; + printk("page= 0x%08x\taddr=0x%08lx\tmap_page=0x%08x\n", + page, + addr, + page_to_phys(page) + offset); + +// return page_to_phys(page) + offset; + return (dma_addr_t)addr; } EXPORT_SYMBOL(dma_map_page); diff -Nru orig/linux-2.6.16.2/drivers/i2c/algos/i2c-algo-oc.c current/linux-2.6.16.2/drivers/i2c/algos/i2c-algo-oc.c --- orig/linux-2.6.16.2/drivers/i2c/algos/i2c-algo-oc.c 2006-04-28 10:23:20.000000000 -0600 +++ current/linux-2.6.16.2/drivers/i2c/algos/i2c-algo-oc.c 2006-04-25 14:40:14.000000000 -0600 @@ -371,8 +371,8 @@ /* -----exported algorithm data: ------------------------------------- */ static struct i2c_algorithm oc_algo = { - .name = "Opencores algorithm", - .id = I2C_ALGO_OC, +// .name = "Opencores algorithm", +// .id = I2C_ALGO_OC, .master_xfer = oc_xfer, .functionality = oc_func, }; @@ -382,13 +382,13 @@ */ int i2c_oc_add_bus(struct i2c_adapter *adap) { - struct i2c_algo_oc_data *oc_adap = adap->algo_data; + //struct i2c_algo_oc_data *oc_adap = adap->algo_data; DEB2(dev_dbg(&adap->dev, "hw routines registered.\n")wink.gif /* register new adapter to i2c module... */ - adap->id |= oc_algo.id; + //adap->id |= oc_algo.id; adap->algo = &oc_algo; adap->timeout = 100; /* default values, should */ diff -Nru orig/linux-2.6.16.2/drivers/i2c/busses/i2c-oc.c current/linux-2.6.16.2/drivers/i2c/busses/i2c-oc.c --- orig/linux-2.6.16.2/drivers/i2c/busses/i2c-oc.c 2006-04-28 10:23:20.000000000 -0600 +++ current/linux-2.6.16.2/drivers/i2c/busses/i2c-oc.c 2006-04-25 14:44:45.000000000 -0600 @@ -46,16 +46,20 @@ static int base0 = 0; static int irq0 = 0; static int clock0 = 0; +#ifdef na_i2c_1 static int base1 = 0; static int irq1 = 0; static int clock1 = 0; +#endif module_param(base0, int, 0); module_param(irq0, int, 0); module_param(clock0, int, 0); +#ifdef na_i2c_1 module_param(base1, int, 0); module_param(irq1, int, 0); module_param(clock1, int, 0); +#endif static void oci2c_setreg (struct iic_oc_hw *hw, int regno, int val) { @@ -166,11 +170,13 @@ .clock = nasys_clock_freq_1000, }; +#ifdef na_i2c_1 static struct iic_oc_hw oc_hw_1 = { .base = na_i2c_1, .irq = na_i2c_1_irq, .clock = nasys_clock_freq_1000, }; +#endif static struct i2c_algo_oc_data oc_data_0 = { .hw = &oc_hw_0, @@ -182,6 +188,7 @@ .timeout = 100, }; +#ifdef na_i2c_1 static struct i2c_algo_oc_data oc_data_1 = { .hw = &oc_hw_1, .setreg = oci2c_setreg, @@ -191,6 +198,7 @@ .mdelay = 10, .timeout = 100, }; +#endif static struct i2c_adapter oc_ops_0 = { .owner = THIS_MODULE, @@ -199,12 +207,14 @@ .name = "Opencores i2c 0", }; +#ifdef na_i2c_1 static struct i2c_adapter oc_ops_1 = { .owner = THIS_MODULE, .id = I2C_HW_OC_UKIT, .algo_data = &oc_data_1, .name = "Opencores i2c 1", }; +#endif static int __init i2c_oc_init(void) { @@ -218,16 +228,7 @@ if (clock0) oc_hw_0.clock = clock0; - if (base1) - oc_hw_1.base = base1; - if (irq1) - oc_hw_1.irq = irq1; - if (clock1) - oc_hw_1.clock = clock1; - - init_waitqueue_head(&oc_hw_0.wait); - init_waitqueue_head(&oc_hw_1.wait); if (oc_hw_init(&oc_hw_0)==0) { if (i2c_oc_add_bus(&oc_ops_0) < 0) { @@ -235,11 +236,22 @@ } } +#ifdef na_i2c_1 + if (base1) + oc_hw_1.base = base1; + if (irq1) + oc_hw_1.irq = irq1; + if (clock1) + oc_hw_1.clock = clock1; + + init_waitqueue_head(&oc_hw_1.wait); + if (oc_hw_init(&oc_hw_1)==0) { if (i2c_oc_add_bus(&oc_ops_1) < 0) { oc_hw_exit(&oc_hw_1); } } +#endif return 0; } @@ -248,8 +260,10 @@ { i2c_oc_del_bus(&oc_ops_0); oc_hw_exit(&oc_hw_0); +#ifdef na_i2c_1 i2c_oc_del_bus(&oc_ops_1); oc_hw_exit(&oc_hw_1); +#endif } module_init(i2c_oc_init);
There are actually several changes here. The first file is just to improve the amount of memory the PCI driver can allocate to devices. Since we used 4 tables setup as
0x0000000 Configuration
0x0010000 I/O
0x0020000 32-bit memory
0x0030000 32-bit memory
we can then use 0x200000 or 2 MB for the memory space from PCI.
The second corrects the problem with the mapping functions that PCI eventually uses.
The third allows the Opencores I2C function to compile and also allows for one I2C module as opposed to two.
This set of diffs is meant for the 2.6.16.2 kernel.
