need to explain .diff file
Hi hippo,
In max140apps.diff,like:
Index: apps/ftpd/Makefile =================================================================== --- apps/ftpd/Makefile    (revision 1) +++ apps/ftpd/Makefile    (working copy) @@ -2,20 +2,21 @@ # configurable options #  - set DEBUG = 1 to turn on debugging support # -DEBUG = 1 +DEBUG = 0 PROJ_NAME = ftpd -INSTALL_DIR = -PROGS := $(PROJ_NAME).exe -CFLAGS += +INSTALL_DIR = ~/rootfs +PROGS := $(PROJ_NAME) +CFLAGS += -O2 PATHDEF_FTPLOGINMESG = -DPATH_FTPLOGINMESG=\"/etc/motd\" PATHDEF_FTPUSERS = -DPATH_FTPUSERS=\"/etc/ftpusers\" PATHDEF_FTPWELCOME = -DPATH_FTPWELCOME=\"/etc/ftpwelcome\" +CROSS       := nios2-linux-uclibc- +CC          := $(CROSS)gcc # # You should not need to modify anything beyond this point # -include Rules.mak ifeq '$(DEBUG)' '1'  PROGS += $(PROGS:.exe=.gdb) @@ -31,11 +32,12 @@ all: $(PROGS) -$(PROJ_NAME).bin: $(FTPOBJS) +$(PROJ_NAME): $(FTPOBJS) +    $(CC) -elf2flt="$(FLTFLAGS)" -o $@ $(FTPOBJS) $(LDLIBS) .PHONY: clean clean: -    -rm -f *. *.elf *.gdb *.bin *.exe +    -rm -f *. *.gdb $(PROJ_NAME) .PHONY: install install: all @@ -43,5 +45,5 @@  $(error No installation directory specified) endif  mkdir -p $(INSTALL_DIR)/bin -    install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin +    install -v $(PROGS) $(INSTALL_DIR)/bin
Does it generate by command diff?
Could you explain it?
Thank you??
No, it is not created with diff.
I use subversion.
svn diff
see
http://nioswiki.jot.com/versioncontrol (http://nioswiki.jot.com/versioncontrol)
