nios&vhdl
I connected vhdl, which is o.k., to a full featured nios 2c35 via a 16bit pio.
The seven segment pio and the parts were removed.
The compilation to the sof and quartus was o.k. too.
So I ran the board test, where deleted the seven segment part. That went o.k.
Then I put the simple socket server in the NIOS IDE. Compilation goes o.k.
But...
Simple Socket Server starting up
Can't read the MAC address from your board (this probably means
that your flash was erased). We will assign you a MAC address and
static network settings
Please enter your 9-digit serial number. This is printed on a
label under your Nios dev. board. The first 3 digits of the
label are ASJ and the serial number follows this.
-->050500368
050500368
[lwIP]: See STDERR for expanded diagnosis translation.
[lwIP]: [init_done_func] Fatal: lwip_devices_init failed, perhaps ethernet inter
face.
[lwIP]: ERRNO: :
[lwIP]: See STDERR (FAULT_LEVEL is SYSTEM).
[lwIP]: FAULT_LEVEL is SYSTEM.
[lwIP]: FATAL Error, Restart required.
[lwIP]: Locking scheduler - endless loop.
What is the reason for this?
Is there a collision between vhdl and the nios core? Would the use of an avalon logic component avoid this problem?
Thanks for your help.
andy
I assume this is a custom board with a CFI flash chip named ext_flash, and a lan91c111 chip.
The 91c111 does not store its MAC address internally; it has to be loaded by the driver during initialization. Altera stores theirs in a part of the flash chip; if you look at the LWIP code, you should see where it goes looking for this during initialization (sorry, I haven't looked at the code myself, so I can't tell you exactly where). You need to either program a new MAC address there, or change the routine to get the MAC address some other way.
