i use BBII LPT1 download cable,in qII5.0,it work fine!
but when i use it in nios2 sdk shell,it don't work! here is the problem$ nios2-terminal.exe
nios2-terminal: There are no JTAG UARTs available which match the --device and
nios2-terminal: --instance options you provided.
jtagconfig tool show: $ jtagconfig
1) ByteBlasterII
020820DD EP1C6
nios2-gdb-server show: $ nios2-gdb-server
Using cable "ByteBlasterII ", device 1, instance 0x00
Pausing target processor: OK
Restarting target processor
why can't it work? who can tell me something? thanks!
now,after i program the flash,i can open the nios2 terminal ,it show message:
<div class='quotetop'>QUOTE </div> --- Quote Start --- [SOPC Builder]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0 nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information. nios2-terminal: starting in terminal mode only (Control-C exits)[/b] --- Quote End --- but if shut down the power of my board,the nios2-terminal will terminate the connection. if i reboot my board,the nios2-terminal can't connect my board, so i must program flash and don't shut down my board, so start nios2 terminal connect success! but i receive nothing , if i use the ecosconfig tool to config the console device as /dev/uart(DB9), i can receive the data from the comm,so i can confirm the flash program has success! but why i don't use jtag uart!!!!- Mark as New
this whole work has three steps(i use ecos for nios2):
1)nios2configtool config the jtag uart as console device; 2)program_flash hello to my board,it succeed! 3)open nios2 sdk shell and run nios2-terminal to receive the "hello world" message. when restart the board,i can't use nios2-terminal to connect to my custom board,is it the sopc custom problem?whether do i must custom the target board again?
