- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am using SOPC Builder to make an user-define peripheral to scan eight 8-segment LED nixietube.
this is the Hardware decription below:
module Display(clk,data,addr,read_en,write_en,data_out,seg,lbit);
input clk;
input read_en,write_en;
input data;
input addr;
output seg;
output lbit;
output data_out;
reg data_in;
reg seg;
reg lbit;
regdata_out;
reg state;
parameter S0 = 1, S1 = 2, S2 = 4,S3 = 8, S4 = 16,S5 = 32, S6 = 64, S7 = 128;
reg clk_div;
initial
begin
data_in=249;
data_in=164;
data_in=255;
data_in=255;
data_in=255;
data_in=255;
data_in=255;
data_in=255;
state=S0;
clk_div=0;
end
always @ (state) begin
case (state)
S0:begin
lbit = 254;
seg = data_in;
end
S1:begin
lbit = 253;
seg = data_in;
end
S2:begin
lbit = 255-S2;
seg = data_in;
end
S3:begin
lbit = 255-S3;
seg = data_in;
end
S4:begin
lbit = 255-S4;
seg = data_in;
end
S5:begin
lbit = 255-S5;
seg = data_in;
end
S6:begin
lbit = 255-S6;
seg = data_in;
end
S7:begin
lbit = 255-S7;
seg = data_in;
end
endcase
end
always @ (posedge clk ) begin
if(clk_div>50_000)begin
clk_div=0;
case (state)
S0:
state <= S1;
S1:
state <= S2;
S2:
state <= S3;
S3:
state <= S4;
S4:
state <= S5;
S5:
state <= S6;
S6:
state <= S7;
S7:
state <= S0;
endcase
end
else
clk_div=clk_div+1;
if(write_en)begin
//write regs
case (addr)
0001:
data_in <= data;
0010:
data_in <= data;
0011:
data_in <= data;
0100:
data_in <= data;
0101:
data_in <= data;
0110:
data_in <= data;
0111:
data_in <= data;
0100:
data_in <= data;
default:
data_in <= data_in;
endcase
end
if(read_en) begin
case (addr)
0001:
data_out <= data_in;
0010:
0011:
0100:
0101:
0110:
0111:
0100:
default:
endcase
end
end
endmodule
the initial display is "1" on the first bit and "2" the 2nd bit this is the configuration : http://img.ph.126.net/ZD_yXFCIY6AtMj75ZRxGwg==/3736298840857749227.png http://img.ph.126.net/00UNXKOVQ0JIQprmfmtG_w==/3736298840857749213.png http://img116.ph.126.net/1-zejQOEktieV5jaHM5D_A==/716916765684060417.png when I debug this Software in Eclipse, # include <stdio.h># include <io.h>
# include "system.h"
int main()
printf("Hello Jack");
IOWR_8DIRECT(DISPLAY_0_BASE,0x30,15);
IOWR(DISPLAY_0_BASE,0x30,5); //display
return 0;
This is the memory when I debug: display_0_base=0x0 http://img.ph.126.net/hsgeXNWqdqjOCDI7WxyG9w==/1529816498423086278.jpg when the software running, I can get the "hello Jack". but the memory doesn`t change. The display doesn`t change either. So where is the problem....Please Give me any Hint^_^
링크가 복사됨
2 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
What stands out is that your are trying to access offset 0x30 meanwhile your component only has a span of 16 bytes. Also when you are doing your address decode you are using decimal like 0010 for example instead of binary 4'b0010.
I'm not quite following what you are trying to do but if your statemachine is supposed to be linear why not just make that a counter? Then decode the counter values independently. Split your read/write logic away from your statemachine (counter) so that you are not attempting to do everything from within a single always block. It'll be much easier to understand and probably faster and smaller in terms of the hardware that gets synthesized.
