12610 Discussions
problem of my coustom nios board?
#! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd F:/multiplexer200507010/standard/software/count_binary_1/Debug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --flash=U23 --offset=0x600000 --input=F:/multiplex
er200507010/standard/standard.sof --output=standard.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert F:/multiplexer200507010/standar
d/standard.sof standard.rbf
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Processing ended: Tue Oct 04 07:59:30 2005
Info: Elapsed time: 00:00:01
WARNING: Default charset GB18030 not supported, using ISO-8859-1 instead
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=standard.flash --sof=$SOPC_KI
T_NIOS2/examples/Multiplexer/system/Multiplexer.sof --base=0x00800000
Oct 4, 2005 7:59:31 AM - (??) nios2-flash-programmer: Launching Quartus Programm
er to download:
D:/altera/kits/nios2_5.01/examples/Multiplexer/system/Multiplexer.sof
Oct 4, 2005 7:59:38 AM - (??) nios2-flash-programmer: Error opening target hardw
are
Oct 4, 2005 7:59:38 AM - (??) nios2-flash-programmer: Unable to open flash-de
vice after successfully communicating
with target.
It is likely that you are using a flash-programming FPGA design which
was not created for your target board.
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. If you wi
sh
to program flash on your own board, you must first create a flash-programming
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
The help-message includes references to other documentation on programming
flash and targeting Nios systems to custom board designs.
- exiting.
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U23 --base=0x00000000 --end=0x7fffff --res
et=0x2100000 --input=count_binary_1.elf --output=ext_flash.flash --boot=$SOPC_KI
T_NIOS2/components/altera_nios2/boot_loader_cfi.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=ext_flash.flash --sof=__NO_SO
F_PLEASE__ --base=0x00800000
Oct 4, 2005 7:59:39 AM - (??) nios2-flash-programmer: Input file empty--no data
to program into flash. Exiting.
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U20 --epcs --base=0x0 --end=0x7fffffff --i
nput=count_binary_1.elf --output=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/co
mponents/altera_nios2/boot_loader_epcs.srec
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=epcs_controller.flash --sof=_
_NO_SOF_PLEASE__ --epcs
Oct 4, 2005 7:59:39 AM - (??) nios2-flash-programmer: SOF-download skipped.
Pre-Reading 75KBytes of data from U20:
********************* (8.468 sec).
Oct 4, 2005 7:59:50 AM - (??) nios2-flash-programmer: Success. Zero bytes writt
en to U20-
(because device matched contents of epcs_controller.flash)
Oct 4, 2005 7:59:50 AM - (??) nios2-flash-programmer: Flash programming complete
sdram is ok,epcs4 is ok ,my program designed is ok,why does my custom board ?
there is my memory test result
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
<----> Nios II Memory Test. <---->
This software example tests the memory in your system to assure it
is working properly. This test is destructive to the contents of
the memory it tests. Assure the memory being tested does not contain
the executable or data sections of this code or the exception address
of the system.
Memory Test Main Menu
a: Test RAM
b: Test Flash
c: Test EPCS Serial Flash
q: Exit
Select Choice (a-b): [Followed by <enter>]a
Base address to start memory test: (i.
e. 0x800000)
>0x2000000
End Address:
>0x20fffff
Testing RAM from 0x2000000 to 0x20FFFFF
-Data bus test passed
-Address bus test passed
-Byte and half-word access test passed
-Testing each bit in memory device. . . failed at address 0x2000034
a: Test RAM
b: Test Flash
q: Exit
Select Choice (a-b): [Followed by <enter>]b
Enter the name of the CFI flash device to be opened,
or just press <enter> to open "/dev/ext_flash")
-ERROR: Could not open /dev/ext_flash
a: Test RAM
b: Test Flash
q: Exit
Select Choice (a-b): [Followed by <enter>]c
Enter the name of the EPCS flash device to be opened,
or just press <enter> to open "/dev/epcs_controller")
-Successfully opened /dev/epcs_controller
-Region 0 contains 8 blocks.
-Checking Region 0 for erased blocks.
-Block 5, at address 0x50000 is erased.
-Would you like to test this block? (y/n)y
-Starting Flash Test.
-Testing "alt_write_flash" and "alt_read_flash".
pass 1 - passed.
pass 2 - passed.
-Testing "alt_erase_flash_block". passed.
-Testing "alt_write_flash_block". passed.
-Testing unaligned writes. passed.
-Returning block 5 to its erased state.
-Flash tests complete.
-Closing flash device "/dev/epcs_controller".
a: Test RAM
b: Test Flash
q: Exit
my ext_ram address is 0x02000000---0x020fffff
ext_flash address is 0x0---0x007fffff
SDRAM address is 0x01000000---0x01ffffff
above program on NIOS2_CYCLONE_DEV_BOARD IS OK;
