I have created the project in SOPC Nios + onchip_ram + jtag_uart + two pio_led + external IRQ + timer + pll + C code. This project with Nios works, all OK. Debug in the IDE works too. After that I in the top project with Nios have added the external module. External module consisting of several hdl files. The external module is not connected with Nios.
After that problems have appeared problems with Debug in the IDE. in console is message Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: OK Initializing CPU cache (if present) OK Downloading 00020000 ( 0%)assertion "m_state == STATE_DEBUG" failed: file "nios2 debug.cpp", line 1757 C:\altera\80\nios2eds\bin\nios2-download: line 594: 1220 Hangup nios2-gdb-server --cable 'USB-Blaster [USB-0]' --instance 0 --tcpport none --w rite-pid ./Debug/nios2-download.pid ./Debug/nios_test_led.elf.srec Sometimes in console is message Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Initializing CPU cache (if present) OK Downloading 00020000 ( 0%) Downloaded 16KB in 0.8s (20.0KB/s) Verifying 00020000 ( 0%) Verify failed between address 0x20000 and 0x23CFF Leaving target processor paused Sometimes in console is message Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused I use Q8.0 sp1. Where there can be a mistake? ThankLink Copied
It's hard to say anything. You need to provide more information.
For example: - is the external module a sopc module? Or maybe is it a component included in your Quartus top level and simply connected to sopc block? - how has the connection to Nios been made? - does your design meets timing constraints? Regards Cris- Mark as New
external module it's my user logic, I have written it without sopc.
Nios has not connection with external module. my design hasnot special timing constraints. Regards serg- Mark as New
the state debug message appeared a long time ago with usb blaster rev b. when we had jtag issues.
we had replaced the flat yellow cable with a short (<10cm) ribbon cable and rechecked that the jtag implmented on our custom boards as mentioned in the device handbooks. could it be that the new added logic just produced more noise and disturbs the jtag ? with added logic the jtag fails without it works ?- Mark as New
--- Quote Start --- with added logic the jtag fails without it works ? --- Quote End --- without added logic jtag is works. line Jtag cable = 15 cm.
--- Quote Start --- my design hasnot special timing constraints. --- Quote End --- Almost every design has timing constraints. You must constrain your design to be sure that it can run at the frequency you use.
--- Quote Start --- Almost every design has timing constraints. You must constrain your design to be sure that it can run at the frequency you use. --- Quote End --- I agree with you, that almost every design has timing constraints. After compilation I have checked that actual frequency = 205MHz and she higher than required frequency = 100MHz. Here all OK. Quartus has any special timing constraints for debug uart?
You should check the hold requirements too. Do you use Timequest or the classical timing analyser?
The timing settings for the debug uart are setup automatically, as long as you give the system clock frequency. Do you have all the licenses or are you in Opencore evaluation mode? In the latter case, be careful not to close the small Opencore alert box, it would make the licensed part stop.- Mark as New
--- Quote Start --- could it be that the new added logic just produced more noise and disturbs the jtag ? with added logic the jtag fails without it works ? --- Quote End --- I have solved the problem. MSchmitt, You are right. After the analysis of jtag signals on pcb, I found a signal which influences on TCK. After I have disconnected him from altera, debug jtag for nios began to work. Thanks all for the help.
your welcome..
is good to know that that little help, helped to solve the problem or even a workaround.
