stand alone LWIP
i'm using Nios II 5.0 IDE version 2.0.0 build 73c. When i try to create a new project "lwip server" i get the message:
"This software template is incompatible with this version of the IDE.
As a result,Cbuild settings for this project will not be set from the template.
Incompatible file:
C:\altera\kits\nios2\examples\software\lwip_web_server\.cdtbuild
File location:
Please contact the provider of this software for an upto-date versione"
any ideas?
I believe it's mentioned in the readme for stand alone lwip. You need to remove the .cdtbuild file and then add the include paths manually.
- slacker
thank u!I've done so and it works.
bye
