12612 Discussions
teraterm setting for sd card boot up. in cyclone 5
I 've just received my board, started to play with the SD card boot, the problem is when i use the teraterm with the setting mentioned, nothing printed out. but when i use the putty software and also same serial setting, it showed the log for the boot.. any one know what are the additional setting i nede to set in order to ues the teraterm connection?
this should be same setting too... what is the problem you see in teraterm actually?
nothing pop up from the black terminal screen, that's the problem.
did you change your option to tera term VT, in good sign? otherwise you will not see some printing from the terminal...in new lines
I will try this and let you know later. I feel using putty is easier.
both should be working the same if the setting is correct...
