u-boot on stratix EP1S40
I am trying to port u-boot on stratix EP1S40 board which is using NIOS-II standard hardware design that comes with altera web edition software (std_1s40.ptf).
I download the u-boot source code from their website..it has some ports for nios and nios-II for different board. ..but not for EPIS40 board.
I was wondering if someone know anything about porting u-boot to startix EP1S40 board for NIOS-II.
1. Make a new configuration file from an existing NIOS2 board...
2. Add a new board directory also from an existing NIOS2 board...
3. Add your board into top Makefile...
4. Compile it (o;
rick
Hi haq,
The PK1C20 configuration _should_ work for the 1S40 board (with some minor tweaks
to include/configs/PK1C20.h). You can give that a try to get your feet wet ... then do
as klingler has suggested.
--Scott
