hardware:apex20K200E
software:quartus+sp1+nios I want to receive the message access the uart .The information is attained by Simense GSM module.Please correct the code as follows: // //#include "buffer.h" // defines RXBUFSIZE and TXBUFSIZE# include <stdio.h># include "excalibur.h"# include "nios.h" # define RXBUFSIZE 256 //#define TXBUFSIZE 256 //Global variables unsigned char RxBuf[RXBUFSIZE]; // the receiver buffer. int RxHead = 0; // the circular buffer index int RxTail = 0; //unsigned char TxBuf[TXBUFSIZE]; // the transmit buffer. //int TxHead = 0; // the circular buffer index //int TxTail = 0; void simpleReceiver1(int context); unsigned char _getchar(); void MyPIO_ISR(int context); int main(void) { int context = 0; int bidir_port_to_and_from_the_led_pio[1]; unsigned char rxchar; np_pio *pio = na_led_pio; nr_installuserisr(na_uart1_irq, simpleReceiver1, context); // install UART ISR (receiver) na_uart1->np_uartcontrol = np_uartcontrol_irrdy_mask; // enable rrdy interrupt while(1) { rxchar = _getchar(); printf("\nfrom RxBuf: %c \n",rxchar); nr_installuserisr(na_button_pio_irq,MyPIO_ISR,(int)pio); pio->np_pioedgecapture = 0; // clear any existing IRQ condition pio->np_piodirection = 0; // all input pio->np_piointerruptmask = 0xff; // they all generate irq's! // bidir_port_to_and_from_the_led_pio[1]=1; } return 0; } // pass an int to make it compatible with nr_installuserisr2 routine // contents of third argument ("context") in nr_installuserisr is passed to ISR void simpleReceiver1(int data) { // put new char into buffer from UART RxBuf[RxHead] = na_uart1->np_uartrxdata; // clear the errors and interrupts na_uart1->np_uartstatus=0; if ((++RxHead) > (RXBUFSIZE-1)) { RxHead = 0; } } //receive _getchar unsigned char _getchar() { //Global variables //unsigned char RxBuf[RXBUFSIZE]; // the receiver buffer. //int RxHead; // the circular buffer index //int RxTail; unsigned char temp; while (RxTail == RxHead) { nr_delay(1); } temp = RxBuf[RxTail]; if (++RxTail > (RXBUFSIZE -1)) { RxTail = 0; } return(temp); } void MyPIO_ISR(int context) { int bidir_port_to_and_from_the_led_pio[1]; np_pio *pio = (np_pio *)context; char s[256]; // a string pio->np_pioedgecapture = 0; // clear the irq condition bidir_port_to_and_from_the_led_pio[1]=1; }Link Copied
