uart interrupt not working
Hi everyone,
I'm using the Altera DE2 board. I am trying to setup a serial link between PC and UART, but UART doesn't seem to be receiving anything. Here's the code that I have. Could anyone tell me what's wrong with it? Thanks. I'm using hyper terminal to send the data and I have jtag_uart mapped as stdin/stdout/stderr to display the char I received through the UART.
# include <stdio.h># include "system.h"# include "sys/alt_irq.h"# include "altera_avalon_uart_regs.h"
# define RRDY_MSK 0x0080
/* Declare a global variable to hold the uart data value */
unsigned char uart_data;
//ISR for receiving
static void IsrRxUart0(void* context, alt_u32 id)
/* cast the context pointer to an character pointer.*/
unsigned char* uart_data_ptr = (unsigned char*) context;
//if RRDY bit of status register is clear
if((IORD_ALTERA_AVALON_UART_STATUS(UART_0_BASE) & RRDY_MSK) == 0x0000)
//IOWR_ALTERA_AVALON_UART_STATUS(UART_0_BASE, 0x0000);
*uart_data_ptr = IORD_ALTERA_AVALON_UART_RXDATA(UART_0_BASE);
// enable UART interrupt for read ready (setting IRRDY bit)
IOWR_ALTERA_AVALON_UART_CONTROL(UART_0_BASE, 0x0080);
/* Initialize the uart */
static void InitUart0()
/* Recast the uart_data pointer to match the
* alt_irq_register() function prototype.
void* uart_data_ptr = (void*) &uart_data;
//enable UART interrupt for read ready (setting IRRDY bit)
//register UART receiver ISR
alt_irq_register(UART_0_IRQ, uart_data_ptr, IsrRxUart0);
int main()
InitUart0();
while(1)
if(uart_data)
printf("This is the character received: %c \n", uart_data);
return 0;
