On kernel 2.6.11 on a NIOSII, I have mounted /usr as jffs2 with the following command in rc script:/bin/mount -t jffs2 /dev/mtdblock3 $RWDIR -n
The /usr fs works fine, but when I go to unmount it: # umount -v /usr -n
mount: could not open /etc/mtab - using /proc/mounts instead
The session hangs http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif From another session, I can see it is still running.. # ps
PID PORT STAT SIZE SHARED %CPU COMMAND
11 S 0K 0K 0.0 mtdblockd
23 S 0K 0K 0.0 jffs2_gcd_mtd3
47 S0 D 151K 0K 0.0 umount -v /usr -n
And the process cannot be killed. How can I get this to unmount correctly? Thanks, Dave
