OpenCL* for CPU
1745 Discussions
Bug in OpenCL debugger
Alexandre_D_1
I have some problems with the Intel Debugger. Here is below and attached a minimal code where you can find the problem (the site doesn't allow .cl extension, so the file is in cpp extension...).
The thing is, I cannot directly give variable adresses to functions who include barriers... Seeing the simplicity of the code, I think it is a bug of your debugger.
I am running this kernel on Windows 7, with Visual Studio 2010, on Intel Core i7-4800MQ CPU, and with a global and local work size of {1,1}.
Thank you in advance for all the help you could provide.
[cpp]
void testFunction(int *test)
// If I delete de barriers, the problem disappears
printf("\tProcessRay , start\n");
barrier(CLK_LOCAL_MEM_FENCE);
printf("\t\ttest value : %i \n", *test);
printf("\tProcessRay , end \n");
return;
__kernel void Kernel_Main()
int test = 10;
int *test2 = &test;
// When I launch this first test, no problem occurs
printf("Lauching test 1 \n");
testFunction(test2);
// Here, I have an exception of memory reading violation... :-(
printf("Lauching test 2 \n");
testFunction(&test);
[/cpp]
Raghupathi_M_Intel
I am not able to reproduce the issue. Can you provide the exact steps and maybe your host code too?
Raghu
Alexandre_D_1
Thank you for the answer, and sorry for the delay.
I have put the project and some images of what I get in the archives attached.
Alex
Yuri_K_Intel
Hi Alex, The issue is reproducible for me, I will submit a ticket and inform you of the investigation results. Thanks, Yuri
Yuri_K_Intel
I also noticed, that the issue happens only when a pointer is calculated as a function argument, I mean: testFunction(&test); Using already calculated pointer: int *test2 = &test; testFunction(test2); doesn't produce this issue (no matter how much time testFunction is called). So I hope you will be able to use this solution as a workaround, Thanks, Yuri
