OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
CL_BUILD_PROGRAM_FAILURE - unknown problem
Lukasz_Swierczewski
[bash] const char* OpenCLSource[] = { "#pragma OPENCL EXTENSION cl_khr_fp64 : enable", "#pragma OPENCL EXTENSION cl_khr_int64_base_atomics : enable", "", "struct complex_double", "{", " double real;", " double imag;", "};", "", "double atom_add_double(__global double* const address, const double value)", "{", " long oldval, newval, readback;", "", " *(double*)&oldval = *address;", " *(double*)&newval = (*(double*)&oldval + value);", " while ((readback = atom_cmpxchg((__global long*)address, oldval, newval)) != oldval) {", " oldval = readback;", " *(double*)&newval = (*(double*)&oldval + value);", " }", " return *(double*)&oldval;", "}", "", "", "__kernel void dqft_ocl_kernel(__global complex_double *q_register, __global complex_double *init, __global unsigned long long *q)", "{", " // Index of the elements to add \n", " unsigned long long int idx = get_global_id(0);", " // Sum the n'th element of vectors a and b and store in c \n", "/* complex_double tmpcomp;", " complex_double tmpcomp2;", "", " double epsilon;", "", " epsilon = pow(10,-14);", "", "", " if ((pow(q_register[2*idx], 2) + pow(q_register[2*idx+1], 2)) > epsilon)", " {", " for (unsigned long long int c = 0 ; c < q[0] ; c++)", " {", " tmpcomp.real = pow(q,-.5) * cos(2*PI*idx*c/q);", " tmpcomp.imag = pow(q,-.5) * sin(2*PI*idx*c/q);", "", " tmpcomp2.real = (q_register[idx].real * tmpcomp.real) - (q_register[idx].imag * tmpcomp.imag);", " tmpcomp2.imag = (q_register[idx].imag * tmpcomp.real) - (q_register[idx].real * tmpcomp.imag);", "", " atom_add_double(&init.real, tmpcomp2_real);", " atom_add_double(&init.imag, tmpcomp2_imag);", "", " //init = complex_add(init, complex_mul(q_register[idx], tmpcomp));", " }", " }", "*/", "}" "", "", "", "", }; void dqft_ocl(complex_double q_register[], unsigned long long int q) { // EN: The Fourier transform maps functions in the time domain to // functions in the frequency domain. Frequency is 1/period, thus // this Fourier transform will take our periodic register, and peak it // at multiples of the inverse period. Our Fourier transformation on // the state a takes it to the state: q^(-.5) * Sum[c = 0 -> c = q - 1, // c * e^(2*Pi*i*a*c / q)]. Remember, e^ix = cos x + i*sin x. complex_double init; unsigned long long i; for(i = 0; i < q; i++) { init.real = 0; init.imag = 0; } // Query platform ID cl_platform_id platform; clGetPlatformIDs (1, &platform, NULL); // Setup context properties cl_context_properties props[3]; props[0] = (cl_context_properties)CL_CONTEXT_PLATFORM; props[1] = (cl_context_properties)platform; props[2] = (cl_context_properties)0; // Create a context to run OpenCL on our CUDA-enabled NVIDIA GPU cl_context GPUContext = clCreateContextFromType(props, CL_DEVICE_TYPE_GPU,NULL, NULL, NULL); // Get the list of GPU devices associated with this context size_t ParmDataBytes; clGetContextInfo(GPUContext, CL_CONTEXT_DEVICES, 0, NULL, &ParmDataBytes); cl_device_id* GPUDevices = (cl_device_id*)malloc(ParmDataBytes); clGetContextInfo(GPUContext, CL_CONTEXT_DEVICES, ParmDataBytes, GPUDevices, NULL); // Create a command-queue on the first GPU device cl_command_queue GPUCommandQueue = clCreateCommandQueue(GPUContext, GPUDevices[0], 0, NULL); // Allocate GPU memory for source vectors AND initialize from CPU memory cl_mem GPUVector1 = clCreateBuffer(GPUContext, CL_MEM_READ_ONLY | CL_MEM_COPY_HOST_PTR, sizeof(complex_double) * q, q_register, NULL); cl_mem GPUVector2 = clCreateBuffer(GPUContext, CL_MEM_READ_WRITE | CL_MEM_COPY_HOST_PTR, sizeof(complex_double) * q, init, NULL); cl_mem GPU_q = clCreateBuffer(GPUContext, CL_MEM_READ_ONLY | CL_MEM_COPY_HOST_PTR, sizeof(unsigned long long int), &q, NULL); // Create OpenCL program with source code cl_program OpenCLProgram = clCreateProgramWithSource(GPUContext, 57, OpenCLSource, NULL, NULL); int err; // Build the program (OpenCL JIT compilation) err = clBuildProgram(OpenCLProgram, 0, NULL, NULL, NULL, NULL); // Create a handle to the compiled OpenCL function (Kernel) cl_kernel OpenCLVectorAdd = clCreateKernel(OpenCLProgram, "dqft_ocl_kernel", NULL); // In the next step we associate the GPU memory with the Kernel arguments clSetKernelArg(OpenCLVectorAdd, 0, sizeof(cl_mem), (void*)&GPUVector1); clSetKernelArg(OpenCLVectorAdd, 1, sizeof(cl_mem), (void*)&GPUVector2); clSetKernelArg(OpenCLVectorAdd, 2, sizeof(unsigned long long int), &GPU_q); // Launch the Kernel on the GPU size_t WorkSize[1] = {12}; // one dimensional Range err = clEnqueueNDRangeKernel(GPUCommandQueue, OpenCLVectorAdd, 1, NULL, WorkSize, NULL, 0, NULL, NULL); clEnqueueReadBuffer(GPUCommandQueue, GPUVector2, CL_TRUE, 0, q * sizeof(complex_double), q_register, 0, NULL, NULL); // Cleanup free(GPUDevices); clReleaseKernel(OpenCLVectorAdd); clReleaseProgram(OpenCLProgram); clReleaseCommandQueue(GPUCommandQueue); clReleaseContext(GPUContext); clReleaseMemObject(GPUVector1); clReleaseMemObject(GPUVector2); vector_normalization_sp(q_register, q); }[/bash] I have a problem. The function clBuildProgram returns CL_BUILD_PROGRAM_FAILURE . Where is the problem?
nikey1
This is where clGetProgramBuildInfo() becomes so useful.
[cpp]size_t log; clGetProgramBuildInfo(program, NULL, CL_PROGRAM_BUILD_LOG, 0, NULL, &log); char *buildlog = malloc(log*sizeof(char)); clGetProgramBuildInfo(program, NULL, CL_PROGRAM_BUILD_LOG, log, buildlog, NULL); printf(buildlog);[/cpp]
put these statements right after your program build call. You can see what exactly is the error..
Raghupathi_M_Intel
You can also use the Intel's offline compiler to see why your program failed to build. But I think your problem may be related to the cl_khr_int64_base_atomics extension. Make sure the particular extension is supported on the platform by calling clGetDeviceInfo() with CL_DEVICE_EXTENSIONS before using any functions supported by the extension.
Raghu
Lukasz_Swierczewski
=== 1 OpenCL platform(s) found: ===
-- 0 --
PROFILE = FULL_PROFILE
VERSION = OpenCL 1.0 CUDA 3.2.1
NAME = NVIDIA CUDA
VENDOR = NVIDIA Corporation
EXTENSIONS = cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll
=== 1 OpenCL device(s) found on platform:
-- 0 --
DEVICE_NAME = Tesla C2050
DEVICE_VENDOR = NVIDIA Corporation
DEVICE_VERSION = OpenCL 1.0 CUDA
DRIVER_VERSION = 260.19.26
CL_DEVICE_EXTENSIONS = cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64
DEVICE_MAX_COMPUTE_UNITS = 14
DEVICE_MAX_CLOCK_FREQUENCY = 1147
DEVICE_GLOBAL_MEM_SIZE = 2817982464
-- 1 --
DEVICE_NAME = GeForce GTS 250
DEVICE_MAX_COMPUTE_UNITS = 16
DEVICE_MAX_CLOCK_FREQUENCY = 1458
DEVICE_GLOBAL_MEM_SIZE = 1073414144
I use nVidia Tesla C2050. This card supports integer atomic functions operating on 64-bit words in global memory (required compute capability >= 1.2).
Why is not available extend cl_khr_int64_base_atomics?
Raghupathi_M_Intel
Because looks like your driver only supports OpenCL 1.0. May be you need to upgrade the driver? 295.59 is the latest driver (from NVidia's website) for this card.
Raghu
Lukasz_Swierczewski
Card does not perform operations on the double. CL_INVALID_BINARY is returned.
I add a pragma:
The device has cl_khr_fp64 extensions. This extension is visible in the system.
This is a problem with the version of OpenCL?
Raghupathi_M_Intel
I am not really sure I understand your problem/question.
Earlier you reported you were running into an issue with cl_khr_int64_base_atomics, but now it appears there is a problem with cl_khr_fp64. Before debugging the issue please make sure you have the latest driver for your device andbefore enabling an extension make sure the device supports it.
Moreover, if you are running on an Nvidia device, please post on their forum since you are most likely to get correct advice there for running applications on their devices.
Raghu
