OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
CPU 1 BANDSTRING-FAIL
Maria3
What does Brandstring-Fail mean? IPDT64- Failed/ Revision: 4.0.5.37.
Also, it states Module Version 1.0.0.10
This option allows you to specify a config xml file/ No config will look for the same name .xml of the exe./Select a conf .xml file to use and omit the .xml extension
Ex: Parallel_Module.exe-config Parallel_Module_AVX_i5-4
No graphics This option will not run any graphics test in the parallel test Graphics tests are defined in the xml file with GraphicsModule
