OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Code Builder initialization failed
peter_b_8
Dears,
per OpenCL installation and running MS Visual Community 2015 I got issue :
Code Builder initialization failed"
Unable to load DLL "KernelBuilderAPI.dll": The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
Peter
peter_b_8
GPU Caps Viewer v1.30.0.0 report
http://www.geeks3d.com
http://www.ozone3d.net/gpu_caps_viewer/
===================================[ System / CPU ]
- CPU Name: Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
- CPU Core Speed: 2594 MHz
- CPU logical cores: 4
- Family: 6 - Model: 12 - Stepping: 3
- Physical Memory Size: 8192 MB
- Operating System: Windows 7 64-bit build 7601 [Service Pack 1]
- PhysX Version: drivers not installed
===================================[ Graphics Adapters / GPUs ]
- Current Display Mode: 1600x900 @ 60 Hz - 32 bpp
- Num GPUs: 1
- GPU 1
  - Name: Intel(R) HD Graphics 4600
  - GPU codename: Haswell(GT2)
  - Device ID: 8086- 416
  - Subdevice ID: 1028- 5BD
  - Revision ID:    6
  - Driver: 10.18.10.3574 (4-24-2014) - GL:ig75icd64.dll
  - Bus Id: -1
  - Shader cores: 20
  - Texture units: 4
  - ROP units: 2
  - TDP: 84W
  - BIOS version: Intel Video BIOS
  - Memory size: 2112MB
  - Memory type:
  - Memory bus width: 0-bit
===================================[ OpenGL GPU Capabilities ]
- OpenGL vendor: Intel
- OpenGL renderer: Intel(R) HD Graphics 4600
- OpenGL Version: 4.2.0 - Build 10.18.10.3574
- GLSL (OpenGL Shading Language) Version: 4.20 - Build 10.18.10.3574
- ARB Texture Units: 8
- Vertex Shader Texture Units: 32
- Pixel Shader Texture Units: 32
- Geometry Shader Texture Units: 32
- Max Texture Size: 16384x16384
- Max Anisotropic Filtering Value: X16.0
- Max Point Sprite Size: 255.0
- Max Dynamic Lights: 8
- Max Viewport Size: 16384x16384
- Max Vertex Uniform Components: 4096
- Max Fragment Uniform Components: 4096
- Max Geometry Uniform Components: 4096
- Max Varying Float: 64
- Max Vertex Bindable Uni
Robert_I_Intel
Hi Peter,
Could you please update your graphics driver from the following https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors​ and try again? Thanks!
peter_b_8
thanks for replay - I can't install driver from your download center since I'm using Dell E6440 and it refuses to install driver from your link. The latest driver DELL is offering:
Intel HD, HD 4000/4200/4400/4600/5000/5100/5200/5300/5500 Graphics Driver.
File Name: Video_Driver_FGGYJ_WN32_10.18.14.4280_A17.EXE
Description: Update Package for Microsoft® Windows® (128.04 MB)
Version: 10.18.14.4280 ,A17
peter_b_8
- Num GPUs: 1
- GPU 1
  - Revision ID:    6
  - Driver: 10.18.14.4280 (8-28-2015) - GL:ig75icd64.dll
  - Bus Id: -1
  - Shader cores: 20
  - Texture units: 4
  - ROP units: 2
  - TDP: 84W
  - Memory size: 1024MB
  - Memory type:
peter_b_8
Issues prevail - same symptoms:
Joose_S_
You should be able to update drivers through windows device manager, or atleast I was on my dekstop dell.
peter_b_8
for driver update I used "win64_153631.4414.exe" and during installing I got:
The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer. Setup will exit.
then I used DELL Video_Driver_FGGYJ_WN32_10.18.14.4280_A17.EXE and even though MS Visual 2015 issue still prevail and have message:
By updating driver thru Device Manager "Automatically for driver software" then driver is "updated" to very old version of year 2013.
Joose_S_
Don't use the "search for drivers autimatically" but rather "browse my comptuer for driver software" and then select the binary you downloaded. This at least worked for me.
peter_b_8
where is binary located ? win64_153631.4414.exe run into troubles but on progress bar you can see some "unpacking" - where those binaries are located to update driver?
Are sure the problem with MS Visual is due to driver version?
peter_b_8
just F.Y.I. Dell is keeping drivers at C:\Drivers folder so when "browse my computer for driver software" it finds DELL drivers. SO I need to know where your driver is copied (what location) from   win64_153631.4414.exe
peter_b_8
