OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1738 Discussions
Crash 32 bit application with Intel CPU Runtime for OpenCL 22
FabianoR
I observed a problem with your new OpenCL runtime ver. 22.
I have an old 32bit application for windows that allows me to detect the OpenCL platforms present in the system and with your new runtime the application throw an exception when the program exits.
I tried to do a very simple test like this:
#include <iostream>
#include "CL/opencl.h"
#include <Windows.h>
int main()
    cl_uint platformIdCount = 0;
    clGetPlatformIDs(0, NULL, &platformIdCount);
    std::cout << "Hello World!\n";
    return (int)platformIdCount;
and I have this exception at the end
This problem is not present with OpenCL runtime ver 21.
Did I do something wrong? Is it a known bug?
I have not found anything about it.
Fabiano
cw_intel
Could you provide the command you used?
I can build from my end,
// main.cpp
#include <iostream>
#include "CL/cl.h"
int main()
  std::cout << (int)platformIdCount << std::endl;
I used the below command to build the code and it could work successfully.​
> icx main.cpp /I"C:\Program Files (x86)\Intel\oneAPI\compiler\2022.0.3\windows\include\sycl" /link "C:\Program Files (x86)\Intel\oneAPI\compiler\2022.0.3\windows\lib\x86\intelocl32.lib"
FabianoR
Hi
I compile the test from VisualStudio and I don't link directly the intel lib intelocl32.lib, but the opencl.lib from nvidia SDK
In the list of the dependent modules there are 2 intel dlls loaded: intelocl32.dll and intelocl32_emu.dll
I saw that the problem is present also if I use LoadLibrary
int main()
    HMODULE hm = LoadLibraryA("OpenCL.dll");
    typedef cl_int(CL_API_CALL* PFN_OPENCL_GET_PLATFORM_IDS) (cl_uint, cl_platform_id*, cl_uint*);
    PFN_OPENCL_GET_PLATFORM_IDS pfnOpenCLGetPlatformIDs = NULL;
    pfnOpenCLGetPlatformIDs = (PFN_OPENCL_GET_PLATFORM_IDS)::GetProcAddress(hm, "clGetPlatformIDs");
    if (pfnOpenCLGetPlatformIDs == NULL)
        return -1;
    // Estraggo le platform disponibili
    pfnOpenCLGetPlatformIDs(0, NULL, &platformIdCount);
    FreeLibrary(hm);
Fabiano
cw_intel
With your loadlibrary code, I still can't reproduce your issue. Could you provide your visual studio output log?
cw_intel
We haven't heard back from you for a long time so we are assuming that you have found a solution on your own. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
FabianoR
I'm sorry, but I also opened a ticket and they recommended me a workaround for the problem.
So
Fabiano
