OpenCL* for CPU
Integer Overflow - AMD and Intel difference
Stephen_H_4
This is my first OpenCL project so I might be doing something wrong but I am having a very strange issue.
Below is my kernel code:
__kernel void collatz(__global int* in, __global int* out)
    uint id = get_global_id(0);
    unsigned long n = (unsigned long)id;
    uint count = 0;
    while (n > 1) {
        if (n % 2 == 0) {
            n = n / 2;
        } else {
            if(n == 1572066143) {
                printf("BEFORE - %lu\n", n);
                n = (3 * n) + 1;
                printf("AFTER  - %lu\n", n);
             } else {
                 n = (3 * n) + 1;
       count = count + 1;
    out[id] = count;
And here is the output:
BEFORE - 1572066143
AFTER  - 421231134
To me it looks as if the "n" variable is overflowing but I can't figure out why that is happening as it is a unsigned long.
The really strange thing is if I update the kernel to set the value of 'n' to 1572066143 then it works correctly.
    uint count = 0;
    while (n > 1) {
        if (n % 2 == 0) {
            n = n / 2;
        } else {
		n = 1572066143;
                n = (3 * n) + 1;
             } else {
                 n = (3 * n) + 1;
       count = count + 1;
    out[id] = count;
Output:
BEFORE - 1572066143
AFTER  - 4716198430
In addition if I run the exact same code on my AMD GPU then I get the correct value.
Please let us know what Processor, Operating System, Graphics Driver Version, and Tool Version you are using:
Processor: i5 4670K (HD Graphics 4600)
Operating System: Windows 10
Graphics Driver Version: 20.19.15.4300
Tool Version: Intel SDK for OpenCL 5.3.0.713
I have attached a zip file containing the host and kernel code.
Any assistance would be great!
Stephen
  1. If code is involved, it is great to create a small "Reproducer" sample and attach it to the message in the form of a zip file
Robert_I_Intel
Hi Stephen,
This looks like a bug in the compiler. Thanks for reporting! I will let the driver people know.
