OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Intel OpenCL auto-vectorization switch
vince_f_
Hi, I want to disable the auto-vectorization of OpenCL kernel on Xeon Phi, is there any way to do that?
Yuri_K_Intel
You may specify __attribute__((vec_type_hint(<typen>))) where typen is some vector type (float3 or char4). Per documentation:
This attribute indicates to the vectorization module apply only transformations that are useful for this type.
So if you specify some type that your kernel is not using it will effectively disable vecorization.
Yuri
vince_f_
I gotcha, Thanks!
