OpenCL* for CPU
1735 Discussions
Intel® SDK for OpenCL™ for Windows* Intel® Software Setup Assistant ended prematurely due to error(s).
Shlok_P_
I got this message when I tried installing this software. It would be really helpful if anyone could help me fix this issue.
Thank You
Jeffrey_M_Intel1
Sorry for the delayed reply.  Could you send some additional info?
  1. System details: what version of Windows are you using?  Which processor?
  2. Which version of Intel SDK for OpenCL are you installing?
It could be helpful to look at the logs at the reported directory.  You may be able to find something yourself with a quick look.  Otherwise, you can attach here or send a private message with "Send Author a Message" if you have any concerns with posting the log publicly.
In general, the approach to Windows installer issues is to 1) remove all previous versions of Intel OpenCL 2) check the logs for clues.
Shlok_P_
I have attached zip of my log files
Operating System: Windows 10 Home 64-bit
System type: x64-based processor
Processor,: Intel Core i5-6198DU
Current opencl version in my laptop is 1.2
I have been trying to install Intel SDK for Opencl applications 2017
Sergey_L_Intel1
Hi Shlok,
Installation failed  due to error on integration with VS2015. Installer reported that some extensions are already installed the by some reason. Could you please try to remove these extensions manually and retry to install:
1) Open VS2015 and got to Tools -> Extensions and Updates
2) Find and uninstall  "Intel adapted Microsoft MI-based Debugger" and  "Intel Debugger for Heterogeneous Compute" extensions.
Shlok_P_
Thank you for your assistance Sergey L.(Intel)
But I do need intel debugger in my Intel Parallel Studio XE and Visual Studio Enterprise edition for academic purposes. Is there any way I could do it without uninstalling "Intel adapted Microsoft MI-based Debugger" and  "Intel Debugger for Heterogeneous Compute"​ because I assume both of these debugger play a major part in compiling code using Intel Debugger. It would be really great if you could suggest me any other solution without uninstalling the Intel Debugger.
Thank You
liu__lixia
Hi Shlok,
I encountered the same problem as you when installing Intel Parallel Studio XE Cluster Edition for windows, so I want to ask you how to solve it in the end?
