OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
**Internal compiler error** Program used external function '__umodti3' which could not be resolved!
kzwarthoed
Hey guys,
Working on a kernel that uses the OpenCL 128-bit 'unsigned long long' datatype, the compiler errors out when fed too many XOR-swap with modulus operations using operands of this type.
Proof of concept kernel:
__kernel void test(__private const uint test) {
    // 128-bit unsigned integers.
    __private unsigned long long a, b;
    a = 15;
    b = 103;
    while (a != 0) {
        // XOR-swap.
        a ^= b;
        b ^= a;
        a ^= b;
        // MOD.
        a %= b;
Output when compiling (Intel OpenCL CPU Runtime 18.1, Linux):
Please report the issue on Intel OpenCL forum
https://software.intel.com/en-us/forums/opencl for assistance.
 Aborted (core dumped)
Kernels not using 'unsigned long long' run fine on same system.
Any help is appreciated
cw_intel
cw_intel
We haven't heard back from you for a long time so we are assuming that the provided details helped you in solving your problem. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
