OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
No luck with debugging OpenCL kernels using VC2013
linuxhippy
I would like to debug my opencl kernel using the opencl debugger plugin within VC2012 (+ Intel SDK for OpenCL Applications 2013 3.0.0.81147; Intel SDK for OpenCL - CPU Only Runtime Package 3.0.1.15216).
Here is what I did:
1. Called clBuildProgram with additional options, as mentioned in the documentation:
    clBuildProgram(program, 1, &device, "-g -s C:\\PathToMy\\File.cl", NULL, NULL)
2. Enabled the OpenCL debugger, told it to trigger at Dim 0/0/0
3. Started debugging. VC2012 seems to halt, but I can't do any actual debugging.
I've recorded a short screencast (at least 720p is adviseable): http://www.youtube.com/watch?v=f4lDWrBbLXE
I would be grateful for any idea what is going wrong here.
Thank you in advance, Clemens
Raghupathi_M_Intel
We are debugging an issue where some users are not able to debug their kernels. I will post here when there is new information.
Raghu
Raghupathi_M_Intel
Can you generate the debug log and attach that here. Set the environment variables
INTEL_OCL_DBG_LOG=1
INTEL_OCL_DBG_LOG_FILE=c:\temp\debugger.txt
and launch Visual Studio. Continue debugging and you should see the debug log under c:\temp.
Raghu
