OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
OpenCL Compiler Bug Report
Steve_Youngs
The compiler is failing with the following simple kernel:
__kernel void test()
float3 a;
if (a.s0 && a.s1 && a.s2)
with an error of
Build Failed!
:4:14: error: invalid operands to binary expression ('float' and 'float')
I'd have expected this to compile OK. It fails in both offline and online compilers. Also fails with || (logical or)
Works correctly with the AMD CPU and GPU compiler.
The workaround is to change the if statement to
if (a.s0 != 0 && a.s1 != 0 && a.s2 != 0)
I'm using Intel OpenCL SDK 1.1
Can you please confirm this is a bug and report it to development?
Steve
Romain_D_
It isn't a bug ; from OpenCL specifications 1.1.36, 6.3 Operators:
"g. The logical operators and (&&), or (||) operate on all scalar and vector built-in types except
the built-in scalar and vector float types."
Romain_D_
Steve_Youngs
Thanks for the clarification Romain. I'll redirect my bug report to AMD for allowing it!
Steve.
