OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
[OpenCL] Using USM on Intel CPU Runtime along with clSetKernelExecInfo(kernel, CL_KERNEL_EXEC_INFO_U
Paulius_V_
Ben_A_Intel
Hi, I had a brief look at this issue. Continuing the discussion from the GitHub issue:
I don't think the call to enable CL_KERNEL_EXEC_INFO_INDIRECT_SHARED_ACCESS_INTEL is required.  The test app isn't making any SHARED allocations, so this call will have no affect.  Enabling CL_KERNEL_EXEC_INFO_INDIRECT_DEVICE_ACCESS_INTEL does have an affect, but because the set of USM pointers is explicitly provided using CL_KERNEL_EXEC_INFO_USM_PTRS_INTEL, enabling indirect access globally for all DEVICE allocations is redundant.
Note: enabling CL_KERNEL_EXEC_INFO_INDIRECT_DEVICE_ACCESS_INTEL does "fix" this issue, but I think this is overkill and shouldn't be required.  Said another way, if the global indirect access flag is enabled then there is no need to pass any set of USM pointers explicitly.
I don't see anything wrong with the call to provide the set of USM pointers with CL_KERNEL_EXEC_INFO_USM_PTRS_INTEL, and it works with several other USM implementations I've tried.
Perhaps a good next step would be for somebody on the CPU OpenCL runtime team to report why the call to clEnqueueNDRangeKernel is returning CL_INVALID_OPERATION when the set of USM pointers is provided explicitly by CL_KERNEL_EXEC_INFO_USM_PTRS_INTEL and indirect access is NOT enabled globally.
Thanks!
