OpenCL* for CPU
1745 Discussions
OpenCL explicit vector alignment for structs
dpshamonin
After checking OpenCL specification (Section 6) for me it is still unclear
whether you have to provide explicit vector alignment for structs initialization.
OpenCL example on different platforms (Intel, NVidia, AMD):
typedef struct
float4 f;
float2 g;
float4 h;
} A;
__constant A a = {0,1,2,3,4,5,6,7,8,9}; // Will compiles fine on Intel and NVidia. FAIL on AMD!!!
__constant A a = {{0,1,2,3},{4,5},{6,7,8,9}}; // Will compiles fine on Intel, NVidia and AMD.
Could you provide some explanation how you would prefer to see it according to the standard?
-Denis
Guy_B_Intel
Hi Denis,
C99 has its standard way to initialize structures by enclosing the initializing values in braces. OpenCL doesn't override this specification.
As for vector elements, the right way to initialize a float4 variable would be:
float4 f = (float4)(0.f,1.f,2.f,3.f);
as stated in the OpenCL 1.1 spec, section 6.1.6.
So the right way to do this whole initialization is:
__constant A d = {(float4)(0,1,2,3),(float2)(4,5),(float4)(6,7,8,9)};
Other forms of initialization might compile, but the result might not be as intended.
For example, __constant A a = {0,1,2,3,4,5,6,7,8,9}; will initialize the first vector (f) with 0 in all its elements, the second vector (g) will be initialized with the value (float2)(1,1), and the third (h) vector will hold (float4)(2,2,2,2). The rest of the initializer list will be thrown away.
Guy
SergeyKostrov
Valued Contributor II
I decided to reproducethe casewith anMS C/C++ compiler ( VS 2005 ). A C structure lookslike:
typedef struct tagA
float f[4];
float g[2];
float h[4];
} A;
So,after initialization avariable 'v' of a type Alooked like:
v.f[0] = 0
v.f[1] = 1
v.f[2] = 2
v.f[3] = 3
v.g[0]= 4
v.g[1]= 5
v.h[0]= 6
v.h[1]= 7
v.h[2]= 8
v.h[3]= 9
in both cases ( described in the initial post ).
It doesn't matter if you declare a set of numbers for initialization with brackets or without brackets.
Sergey
