OpenCL* for CPU
OpenCL program crashes in processor graphics (P4000)
Surendar_C_
Build log claims:
   fc1 build 1 succeded.
   fc1 build 2 succeeded.
Error: Internal Error.
The same program works fine on the CPU; it only fails in the GPU. Any pointers on where to start? Thanks much (I am using OpenCL 2012 on a Windows 7 Pro with Visual Studio 2010 Express). I cannot install 2013, it fails for both the 32 bit and 64 bit versions)
Yuri_K_Intel
Hi! Could you please attach a reproducer for this issue? Regarding the 2013 installer failure - could you please also provide the details (have you removed 2012 version before that or not, at which step and what exactly the error message is)? Thanks, Yuri
Surendar_C_
Regarding the 2013 installer failure: I've tried removing 2012, reinstalling Win7 and leaving the 2012 on. The results are the same, it goes through to asking "Do you wish to install these components", then to "Intel SDK for OpenCL application"-> I agree to EULA, leave the default Components, choose Integrate with Microsoft Visual Studio 2010 software (I am using VS Express) and when I hit install, the progress meter moves up towards Copying Files and then it quickly rolls back (too fast for me to see) and then brings up a screen, "Intel SDK for OpenCL Applications 2013 Beta setup Wiward Ended Prematurely because of an error. ..." message. There are no helpful messages on what the error actually was. I am using WIn 7 Pro. Update: Once I installed Visual Studio 2010 Ultimate, I was able to install OpenCL 2013 beta (looks like the installer was automatically trying to remove the old CPU only RunTime package and failing/crashing)
Surendar_C_
I suspect that this code has a syntax or some sort of an error. It core dumps before it gets there. (Its a .cl file, the uploader only allows .c though) Update: this code fails with the same error with 2012 and 2013 (beta)
Yuri_K_Intel
Hi Surendar! I'm glad to hear you solved the installation issue. Actually it is reproducible on our side (with only VS 2010 Express installed). A workaround that can be used (if you ever need to work in such setup) - launch the installer, clear 'Remove temporarily extracted files' checkbox. After the extraction cancel the installation and install vc redistributable files - they can be found in extracted files. And then launch the installer again. As for the kernel compilation issue - I have been able to reproduce it as well. I will pass the information to the relevant team for the investigation. One comment that I have right now - there are a lot of #ifdefs (that were inherited from c version obviously), but since none of them would make sense in OpenCL code I'd suggest some cleanup. Thanks, Yuri
Yuri_K_Intel
Hi, An update on kernel compilation issue. It has been fixed and should be available in the next driver release. Thanks, Yuri
Surendar_C_
Thanks Yuri. Any time frame on when I can get access to the new driver? Thanks again
ARNON_P_Intel
We will use this forum to notify when the new driver is released. Stay tuned.
Aenon
Yuri_K_Intel
Hi, Sorry for the delay. An update for the drivers version. Latest available drivers (15.​31.​9.​3165) contain the fix for this issue. Thanks, Yuri
Yabin_D_Intel
I meet the same problem ,and I am using Intel® SDK for OpenCL™ Applications 2014  on a Windows 7 Pro with Visual Studio 2012.
Robert_I_Intel
Hi Yabin,
Any chance you could use the latest and greatest Intel(R) OpenCL Code Builder from Intel(R) INDE https://software.intel.com/en-us/intel-inde/try-buy? Please update to the latest version and also make sure that your graphics driver is up to date. You can get it from here https://downloadcenter.intel.com/
