OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
OpenGL, glDraw random GL_INVALID_OPERATION error.
Romain_c_
Sorry If I have posted this twice but I can't find my topic :/
I have a bug in my program I have "resolved" but I can't figure out why it is happening :/ I am using the latest sdk and glfw. I have one vbo that is shared with openCL, when I render I get random GL_INVALID_OPERATION after a draw operation, so sometimes things are draw and sometimes the screen is black. (Even if I use an empty kernel I get this problem and if I run the program using nvidia implementation I don't have this problem.)
My loop is like that: 1) draw
                              2) execute kernel.
Here is the render code when it bugs (note that a vao is already bound):
[cpp]
glClear(GL_COLOR_BUFFER_BIT);
GLenum glError = glGetError();
glDrawElements(GL_TRIANGLES, NUM_INDICES * num_bacterias, GL_UNSIGNED_INT, NULL);
assert (GL_NO_ERROR == glError);
glfwSwapBuffers();
return viewer_no_error;
[/cpp]
Here is the render code when it works:
[cpp]
    glBindVertexArray(bacteria_vao);
    // Render code here.
                   GL_UNSIGNED_INT,
                   NULL);
    glfwSwapBuffers();
    glBindVertexArray(0);
[/cpp]
Here is where I execute the kernel:
[cpp]
cl_engine_status_t cl_engine_step_1D (const cl_engine_t* engine,
                                      const char* kernel,
                                      cl_buffer_t** buffers_to_acquire,
                                      int num_buffers,
                                      size_t work_size,
                                      size_t local_work_size)
    cl_int err;
    size_t g_work_size[1] = {work_size};
    size_t l_work_size[1] = {local_work_size};
    cl_mem* buffers = alloca(sizeof(cl_mem) * num_buffers);
    if (0 != num_buffers && NULL != buffers_to_acquire)
        for (int i = 0; i < num_buffers; i++)
            buffers = buffers_to_acquire->buffer;
        glFinish();
        err = clEnqueueAcquireGLObjects(engine->queue,
                                        num_buffers,
                                        buffers,
                                        0,
                                        NULL,
                                        NULL);
        if (CL_SUCCESS != err)
            return cl_engine_failed_sync_buffers;
    err = clEnqueueNDRangeKernel(engine->queue,
                                 get_kernel(&engine->program, kernel),
                                 1,
                                 NULL,
                                 g_work_size,
                                 0 == local_work_size ? NULL : l_work_size,
                                 0,
                                 NULL,
                                 NULL);
        return cl_engine_failed_to_enqueue_kernel;
        err = clEnqueueReleaseGLObjects(engine->queue,
                                        num_buffers,
                                        buffers,
                                        0,
                                        NULL,
                                        NULL);
    clFinish(engine->queue);
    return cl_engine_no_error;
[/cpp]
So the only thing that change is that I rebind everytimes before rendering. I thought opencl was unbinding the vao but glGetIntegerv(GL_VERTEX_ARRAY_BINDING, &current_vao) always report that my vao is bound. I have tested with opengl 4.3 and 3.3.
Thanks in advance for any possible help ! :)
