OpenCL* for CPU
1745 Discussions
Relative include paths don't work in clBuildProgram
ABoxe
I am using the 2014 beta SDK.
I would like to pass "-I  RELATIVE\\PATH\\TO\\FILES" in as a build parameters, but this doesn't work.
I have to pass the absolute path instead. So, this forces me to hard code the build path, which is annoying
when I try building from a different location.
Aaron
Yuri_K_Intel
Hi, I can't reproduce this issue (I'm using 2013 version of the SDK though, but I don't think this is important here). I have created a kernel file with single line: #include "kernel.cl" And I'm passing relative path in build options to clBuildProgram like this for example: "-I..\\..\\FolderWithKernels" And it works fine. So please double check that you're passing correct path. Thanks, Yuri
ABoxe
Thanks, Yuri.  I should clarify: this is only a problem when targetting my AMD GPU using the Intel SDK.
When I target the Intel CPU, I don't even need to enter an include path.
Cheers,
Aaron
Yuri_K_Intel
In this case you should ask this question on AMD forum. Since when you run the application and, as you say - target AMD GPU, you're selecting AMD platform (and the device, of course), so it's AMD runtime which builds the cl program. Thanks, Yuri
ABoxe
OK, thanks Yuri.
