OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Suggestion: add define table control to Offline compiler
jogshy
Pls, add a 2-colums table control to the offline kernel precompiler tool so we can assign our C "defines" in an easier way that passing them using the build option "-D".
As it's done in the ATI's SKA tool will be fantastic, pls.
Also, you should add an option to save the whole "project" and not only the .cl source or I'll loose the defines once I close the program.
On the other hand, you should save the current .cl source code and options and to recover all them when the program opens again.
Shiri_M_Intel
Hi
Very interesting ideas, we like them!!
We will add this in future releases
Thanks, Shiri
