OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1736 Discussions
Trying to install SDK on a linux system
John_Russell
Greetings,
I am looking to install on a Linux system, CentOS 5.4, with an NVIDIA GPU dev SDK installed. The CPU is a Core 2 Duo P9300. Does that count as a 9000 series or would I be wasting my time to try to install the Intel SDK?
JR
Uri_L_Intel
Hi John,
Yes, ourSDK supports theCore 2 Duo P9xxx processors series (and P9300 in particular).
Uri
John_Russell
Thanks Uri...now for the real problem. When I try to install, it appears there are a few things missing and/or out of date. I can find my way around 'nix systems ok but am installation- and lib-challenged. Below is a capture of my attempt to install OpenCL. Any insight to packages needing installation and/or updates are greatly appreciated.
[root intel]# rpm -i intel_ocl_sdk_1.1_beta_lnx_64.rpm
error: Failed dependencies:
libc.so.6()(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libc.so.6(GLIBC_2.2.5)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libc.so.6(GLIBC_2.3.2)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libc.so.6(GLIBC_2.3.4)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libc.so.6(GLIBC_2.3)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libdl.so.2()(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libdl.so.2(GLIBC_2.2.5)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libgcc_s.so.1()(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libgcc_s.so.1(GCC_3.0)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libgcc_s.so.1(GCC_3.4)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libgcc_s.so.1(GCC_4.0.0)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libm.so.6()(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libm.so.6(GLIBC_2.2.5)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libnuma.so.1()(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libnuma.so.1(libnuma_1.1)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libnuma.so.1(libnuma_1.2)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libpthread.so.0()(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libpthread.so.0(GLIBC_2.2.5)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libpthread.so.0(GLIBC_2.3.2)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
librt.so.1()(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
librt.so.1(GLIBC_2.2.5)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libstdc++.so.6()(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libstdc++.so.6(CXXABI_1.3.1)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libstdc++.so.6(CXXABI_1.3)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libstdc++.so.6(GLIBCXX_3.4)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
libstdc++.so.6(GLIBCXX_3.4.9)(64bit) is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
rpmlib(PayloadIsLzma) <= 4.4.2-1 is needed by intel_ocl_sdk_SUSE+11.1-1.1-1.x86_64
[root intel]#
Romain_D_
Apparently, the version required by the SDK for some software is higher than what you have, and you need to upgrade.
You can find the exact package supplying a library by
1) looking for the location of the file itself in the filesystem
2) using rpm to find the exact package supplying that file
i.e. for 1) by using 'locate' (if installed) or 'find':
# find / -name libc.so.6
should point you to /lib64/libc.so.6 & maybe /lib/libc.so.6 ; on a 64 bits system you care for the first, so for 2):
# rpm -q -f /lib64/libc.so.6
on one of my systems it returns "glibc-2.5-42.el5_4.2"
so you would need a newer glibc package (& all the associated development packages) for your distribution. Same for all the other files. Unfortunately, most of them are from the base system, so you may be better off upgrading the entire distibution.
if a file is completely missing (you may not have the NUMA stuff by default, for instance), then I would suggest looking for it on "http://rpm.pbone.net/" to find the exact package to install.
HTH
lystor
libc.so.* are provided by glibc-2.5-58.el5_6.3.x86_64.rpm
You can use Linux Packages Search (pkgs.org) to resolve other dependencies.
