- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi, I have encountered a crash problem running for Intel CPU on Windows 7 (x86) platforms with OpenCL CPU only. My platforms is below, CL_PLATFORM_NAME: Intel(R) OpenCL CL_DEVICE_NAME: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz CL_DEVICE_VERSION: OpenCL 1.2 (Build 57) CL_DRIVER_VERSION: 5.0.0.57
I use only 3 cores for windows 7 system, and 1 core for RTOS system.
Mostly, it works fine when I repeat do the life time test when OpenCL run in CPU.
However, I got the following information in console mode and then crash.
Currently, I just got only one situation like this. Still try to duplicate it.
I don't have idea about it. Can anyone give me a hint of it?
0x0A091938 (0x10FFA080 0x0E5C56B8 0x0E5C56AC 0xA1F21EAB) <unknown module>
0x57BDACD0 (0x10FFA080 0x0E5C56B8 0x0E5C56AC 0x00000000)
0x5968E3E3 (0x00000000 0x00000098 0x00000000 0x07E272B8), clDevInitDeviceAgent() + 0x3833 bytes(s)
0x5973E908 (0x0D9FED24 0xA1F33BDF 0x0DA03E80 0x0D9FED20), ?GetTaskExecutor@TaskExecutor@OpenCL@Intel@@YAPAVITaskExecutor@123@XZ() + 0x7EB8 bytes(s)
0x59739019 (0x0D9FED20 0x0D9FED24 0x5830A4F0 0xA1F26F16), ?GetTaskExecutor@TaskExecutor@OpenCL@Intel@@YAPAVITaskExecutor@123@XZ() + 0x25C9 bytes(s)
0x5973EF0C (0x0DA07F20 0x0D9FED20 0x0DA23F88 0x00000001), ?GetTaskExecutor@TaskExecutor@OpenCL@Intel@@YAPAVITaskExecutor@123@XZ() + 0x84BC bytes(s)
0x58305439 (0x00000000 0x00000000 0x0DA27F08 0x0DA27F00), ?internal_current_slot@task_arena_base@internal@interface7@tbb@@KAHXZ() + 0xEB9 bytes(s)
0x583036B6 (0x0DA03E80 0x00000000 0x0DA27F00 0x0E5CF748), ?initialize@task_scheduler_init@tbb@@QAEXH@Z() + 0xD16 bytes(s)
0x582FE5E8 (0x00000000 0x00000000 0x00000000 0x00000000), ?thread_sleep_v3@internal@tbb@@YAXABVinterval_t@tick_count@2@@Z() + 0x1338 bytes(s)
0x0A091901 (0x10FFA080 0x0E7CB7D0 0x0E7CB7C4 0xA1D2FF93) <unknown module>
0x57BDACD0 (0x10FFA080 0x0E7CB7D0 0x0E7CB7C4 0x00000000)
0x5968E3E3 (0x00000000 0x00000097 0x00000000 0x07E272B8), clDevInitDeviceAgent() + 0x3833 bytes(s)
0x5973E908 (0x0D9FE824 0xA1D3DAF7 0x0D9FBE80 0x0D9FE820), ?GetTaskExecutor@TaskExecutor@OpenCL@Intel@@YAPAVITaskExecutor@123@XZ() + 0x7EB8 bytes(s)
0x59739019 (0x0D9FE820 0x0D9FE824 0x5830A4F0 0xA1D28EFE), ?GetTaskExecutor@TaskExecutor@OpenCL@Intel@@YAPAVITaskExecutor@123@XZ() + 0x25C9 bytes(s)
0x5973EF0C (0x0D9FEF20 0x0D9FE820 0xA1D28EC2 0x0E7CBB30), ?GetTaskExecutor@TaskExecutor@OpenCL@Intel@@YAPAVITaskExecutor@123@XZ() + 0x84BC bytes(s)
0x58308332 (0x0D9FF520 0x0D9FF51C 0xA1D3D8D7 0x00000000), ?internal_wait@task_arena_base@internal@interface7@tbb@@IBEXXZ() + 0x2382 bytes(s)
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
It would be good to have a reproducer: a small repeatable program that can demonstrate this crash. You should be able to call OpenCL from multiple threads with no issues.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
To help to diagnose, please enable OpenCL API calls logger via CL_CONFIG_USER_LOGGER=I environment variable.
Documentation is here https://software.intel.com/en-us/node/540601
Please provide the resulting log file.
Thank you!
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I don't have a reproducer and it is hard to trigger this issue after CL_CONFIG_USER_LOGGER=I, filename is set.
If I can duplicate the issue, I will provide the log file immediately.
However, I have a little question, would you please kind teach me ?
If I got platform ID, device ID, context, build program and create Kernel only at the begin of the program.
and then I use the them to run clEnqueueNDRangeKernel at multithread thread with the same command queue and kernel, it is legal or not?
Or I should claim those resource at each thread?
Thanks a lot for your instant reply.
Alpha
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Alpha,
You should have no issues submitting commands to the same queue from different threads, so yes, what you are doing is very legal.
