OpenCL* for CPU
Virtualbox and __ocl_svml_u8.so
Jori_Mäntysalo
OpenCL application on Fedora 20 on host machine works, and strace says that it loads __ocl_svml_e9.so. On vmachine inside Virtualbox the program fails at clCreateContext; strace says it doesn't find __ocl_svml_u8.so.
/proc/cpuinfo at host machine says that model name is Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz, stepping is 9 and cpuid level is 13. On virtual machine cpuid level is 5. Is this related?
Is there some deep problem with OpenCL and virtualization? If not, known problem  with Virtualbox?
Yuri_K_Intel
Hi Jori, One possible reason could be the absence of SSE4.1 instructions inside the guest OS. Please see the corresponding ticket - https://www.virtualbox.org/ticket/8651. It has been updated just a few days ago - you need to use the latest VirtualBox RC to give it a try. This is just a suggestion though, i didn't check it myself. Please, post the results here. Thanks, Yuri
Jori_Mäntysalo
That was it. Thanks!
However, page at http://software.intel.com/en-us/articles/opencl-sdk-frequently-asked-questions#14 says "support - - is limited to - - SSE 4.1 or higher." After VBoxManage setextradata name-of-vmachine VBoxInternal/CPUM/SSE4.1 1 it didn't work. Anyways, same with SSE4.2 makes this to work.
Another thing, isn't there some kind of bug? Some code refers to non-existing .so -file.
Yuri_K_Intel
Thanks for following up. I have created a ticket to resolve the issues with non-existing .so file and documentation (SSE 4.1 vs 4.2). Thanks, Yuri
